Anthonyl79's BUILD - 2005 GMC Envoy
- After the lift
- 292874_4614325354305_2123396477_n.jpg (39.87 KiB) Viewed 26924 times
2005 GMC Envoy SLT
Drivetrain Specs:
5.3 V8
3.73 Front open diff
3.73 G80 in the rear
Suspension Modifications:
installed ~ Z-71 rear springs;
installed ~ moog 81114 front springs
installed ~ markmc 2.5" lift
installed ~ 1.5" spacers
installed ~ 265/70R17 DynaPro ATM
installed ~ Monroe Sensatrac front struts and rear shocks
planned ~ process of installed Dana 44, 4 link front and pushing rear diff back
planned ~ 35" tires
Exterior Modifications:
installed ~ custom front bumper w/shackle mounts, 2" receiver
installed ~ custom rear bumper w/shackle mounts, 2" receiver and spare tire carrier
installed ~ radiator skid plate
installed ~ oil pan skid plate
installed - Auxbeam 12" 2 row led light bars x2 front bumper
installed - Nitlite 4" leds, tiggle switched and on reverse switch - rear bumper
installed ~ Plasti dipped wheels black
installed ~ 4' Firestik antenna, with Dodge Dakota mount
installed ~ Led headlamps instead of the HIDs
removed ~ side moldings
Engine - Drivetrain
installed ~ Spal E-Fan with custom shroud
installed ~ 3" exhaust and resonator delete
installed ~ 5.3L Swap
- 04 trailblazer 5.3l
- LS 9 corvette cam
- Custom 4" CA I
- HP Tuners
- Complete trans rebuild
- Beast sunshell
- Dual cage sprays
- Kevlar band
- painless accumulators
- .50 boost valve
- hardened seats on the separator plate
- red frictions and new steels
- 04 trailblazer bellhousing
- 04 buick reiner front and rear drive shafts
- 2500 stall converter
- custom transmission crossmemeber
Interior Modifications:
installed ~ custom center console safe
installed ~ Bearcat 980ssb
installed ~ Custom switch panel
installed ~ Blue LEDS for dash lights
installed ~ Rear seat removal pins
Recovery Equipment:
1 - 20' 44k recovery rope
1 - 20' 22k recovery rope
2 - 20' 10k tow ropes
snatch block, 7/8" screw pin shackles, 3/4" screw pin shackles
ratchet straps
installed ~ hi-lift jack with winch add-on
installed ~ Superwinch TigerShark 9.5 with roller fairlead
installed ~ air outlet under the hood
installed ~ Viair Air constant duty air compressor w/tank
Electrical Modifications:
installed ~ yellow top Optima battery
installed ~ custom 2/0 battery cables, plus upgraded the cable that feeds the fuse block
installed ~ 2/0 negative battery cable battery to frame
installed ~ quad headlights
installed ~ 900w power inverter
installed ~ custom 2gauge 20' jumper cables with Anderson Connector
installed ~ front and rear Anderson Connector in bumpers
installed ~ Kenwood bluetooth stereo
installed ~ Pionner 2 channel amp
installed ~ Clarion front door and tweeters
installed ~ Sony 800w 2 channel amp for 2 12" Terminator subs
installed ~ moved battery to rear storage compartment
