Anthonyl79's GMC build
by anthonyl79 » Tue Feb 17, 2015 12:02 am
Anthonyl79's BUILD - 2005 GMC Envoy
After the lift
2005 GMC Envoy SLT
Drivetrain Specs:
5.3 V8
3.73 Front open diff
3.73 G80 in the rear
Suspension Modifications:
installed ~ Z-71 rear springs;
installed ~ moog 81114 front springs
installed ~ markmc 2.5" lift
installed ~ 1.5" spacers
installed ~ 265/70R17 DynaPro ATM
installed ~ Monroe Sensatrac front struts and rear shocks
planned ~ process of installed Dana 44, 4 link front and pushing rear diff back
planned ~ 35" tires
Exterior Modifications:
installed ~ custom front bumper w/shackle mounts, 2" receiver
installed ~ custom rear bumper w/shackle mounts, 2" receiver and spare tire carrier
installed ~ radiator skid plate
installed ~ oil pan skid plate
installed - Auxbeam 12" 2 row led light bars x2 front bumper
installed - Nitlite 4" leds, tiggle switched and on reverse switch - rear bumper
installed ~ Plasti dipped wheels black
installed ~ 4' Firestik antenna, with Dodge Dakota mount
installed ~ Led headlamps instead of the HIDs
removed ~ side moldings
Engine - Drivetrain
installed ~ Spal E-Fan with custom shroud
installed ~ 3" exhaust and resonator delete
installed ~ 5.3L Swap
- 04 trailblazer 5.3l
- LS 9 corvette cam
- Custom 4" CA I
- HP Tuners
- Complete trans rebuild
- Beast sunshell
- Dual cage sprays
- Kevlar band
- painless accumulators
- .50 boost valve
- hardened seats on the separator plate
- red frictions and new steels
- 04 trailblazer bellhousing
- 04 buick reiner front and rear drive shafts
- 2500 stall converter
- custom transmission crossmemeber
Interior Modifications:
installed ~ custom center console safe
installed ~ Bearcat 980ssb
installed ~ Custom switch panel
installed ~ Blue LEDS for dash lights
installed ~ Rear seat removal pins
Recovery Equipment:
1 - 20' 44k recovery rope
1 - 20' 22k recovery rope
2 - 20' 10k tow ropes
snatch block, 7/8" screw pin shackles, 3/4" screw pin shackles
ratchet straps
installed ~ hi-lift jack with winch add-on
installed ~ Superwinch TigerShark 9.5 with roller fairlead
installed ~ air outlet under the hood
installed ~ Viair Air constant duty air compressor w/tank
Electrical Modifications:
installed ~ yellow top Optima battery
installed ~ custom 2/0 battery cables, plus upgraded the cable that feeds the fuse block
installed ~ 2/0 negative battery cable battery to frame
installed ~ quad headlights
installed ~ 900w power inverter
installed ~ custom 2gauge 20' jumper cables with Anderson Connector
installed ~ front and rear Anderson Connector in bumpers
installed ~ Kenwood bluetooth stereo
installed ~ Pionner 2 channel amp
installed ~ Clarion front door and tweeters
installed ~ Sony 800w 2 channel amp for 2 12" Terminator subs
installed ~ moved battery to rear storage compartment
anthonyl79
by anthonyl79 » Tue Feb 17, 2015 3:25 am
Started with the trim molding removal. Found a great tutorial on another site, won't mention the name. Used fishing line and a 3M adhesive remover. Then deleted the resonator.
Then came along the HID kit. The first kit I installed was from JetttStream that I cant remember that offered the kit to install quad beam head lamps. The bulbs failed shortly after and couldn't get new ones from him. Found this place through a buddy of mine and they have not failed me in 4 years now. http://www.ddmtuning.com/
The custom intake was next. Had some piping sitting on a jobsite so I grabed some and made this guy up. Running a K&N filter and did the intake box mod as well.
I will post some more of the mods that I have done here in the near future.
******Before anyone says anything about the front and rear gears not matching, thats right some idiot (ME) ordered the rear diff from the junkyard with the wrong ratio in it. Instead of the 3.42's that where factory I for some reason though it had 3.73's. So now I have not 4x4. That is why I am doing the SAS finally. ******
anthonyl79
by anthonyl79 » Sat Oct 24, 2015 1:34 am
Well blew the 4.2 up (For the second time). Started knocking so the rig has been sitting for 5 months now :(
So I am now moving forward with the 5.3 swap.
Engine Mods
LM4
LS9 Cam Factory Gm Part Number 12638427
GM Performance Valve springs 12499224
Milled heads, blended bowls
Trickflow timing chain tensioner
LS2 timing cover 12633906
LS2 Timing chain - 4x Timing Gear set for moving the cam gear to the front. 9-3672TX9 Cloyes
2200 Stall Converter
anthonyl79
by anthonyl79 » Sun Nov 01, 2015 5:49 pm
Well here are a couple of updated photos. Working on the wiring for now. The harness came from a 03 Silverado and the ECM from a 04 Silverado. Fun thing about the 03 harness it uses a different PNP switch. )3 used two plugs and the 04 and up uses a single large plug. So little more wiring that needed to be done that didnt plan on.
Motor is ready for install just need more money to rebuild the transmission. So fell free to send some my way :excited: ;)
anthonyl79
by anthonyl79 » Thu Mar 17, 2016 7:09 pm
Well time for an update. The transmission done. Updated hard parts, Sonnex pinless 1-2, 3-4 acumulator pistons, vette servo, hardened seats on the separator plate. New 2800 stall converter and of course new bellhousing.
Search is on for an alternator, power steering pump, mass air flow sensor and starter. Also need some 3.73 gears for the front 7.2 diff.
anthonyl79
by anthonyl79 » Fri Apr 15, 2016 5:04 pm
So the wiring is done, until it's ready to fire. Got the transmission and transfer case in. The back of the new 5.3 sits 2.5 inches more forward than the back of the 4.2, so had to fab the transmission crossmemeber. The 4.2 and the 5.3 Envoys and Trailblazers use the same crossmemeber but have different mounting locations.
Picked up a 2006 5.3 4x4 Trailblazer driveshaft. 4.2 driveshaft measures 36" from center of ujoint to center of ujoint. 5.3 measures 38.5 center to center. Ujoints are the same so no biggie.
That's about it for now. Next is fuel lines and some more fabing. Moving the batter to the rear and going to run two batteries.
anthonyl79
by anthonyl79 » Sun Aug 21, 2016 7:09 pm
Here are some more pictures.
CB Radio Trim ring in process
CB radio trim
CB and trim installed
CB installed
Switch Panel
Switch Panel
Trans cross member started. Forgot to get after pics.
Cross-member
Front and rear bumpers with lights added
Front
Rear
Batter used to be here now its the new home for relays and PCM
ECM Mount
Dashlights converted to LEDs
Dashlights
anthonyl79
by anthonyl79 » Sun Aug 21, 2016 7:30 pm
Well Navigator I hope this gets me to the offroad rated section and out of the mall cruisers.
Last summer camping trip to Estes Park
Here is a trail description
http://www.traildamage.com/trails/index.php?id=188
Poll Hill Road - Estes Park Colorado
Pole Hill Road Estes
Nice little sideshot.
Nice side shot
Dont let her know I posted this one. You can touch the ground out her window. Got in a little trouble from her for that one.
Dont tell her I posted this one.
anthonyl79
by anthonyl79 » Sun Aug 21, 2016 7:41 pm
Lake McConaughy Nebraska
This is from last summers yearly trip to lake Mac. We always stay at Sandy Beach north east side. Like this little place. Drive up and down the beach, nice little hills to crawl around on. One of the favorite places to camp.
Some people shouldn't be driving on the beach. Had to pull them out after they buried the minivan.
MiniVan
My dogs and wife
Buddy
Buddy
Sasha my Shepard and the wife
Jamie and Sasha
Chole the lab driving the Envoy
Chloe
Headed down to the water for the day
Lake
anthonyl79
Return to Mall Rated Builds
