by Trail X » Tue Sep 03, 2013 10:50 am
The key is to wrap it in a plastic bag, and hang it from above, through the handles. Then unscrew the filter, let it drop into the bag, and lower the bag to the ground.
by HARDTRAILZ » Tue Sep 03, 2013 11:14 am
I just let it dump on the ground. It came from there and can go back there.
by bgwolfpack » Tue Sep 03, 2013 11:19 am
I always have a kid around. Kids are great for clean up.
by Trail X » Tue Sep 03, 2013 11:26 am
I just hated getting oil down my arm and shirt.
by Moots1288 » Tue Sep 03, 2013 12:04 pm
JamesDowning wrote:I just hated getting oil down my arm and shirt.
ahh it'll be alright a little oil don't hurt no body
by jonbo2002 » Tue Sep 03, 2013 12:28 pm
the oil isn't the problem, its pulling the filter that i have a problem with. such a compact space for my fliter wrench
jonbo2002
by Moots1288 » Tue Sep 03, 2013 12:39 pm
jonbo2002 wrote:the oil isn't the problem, its pulling the filter that i have a problem with. such a compact space for my fliter wrench
You got to finagle the wrench in there, take your time.. Don't be like me.. And if you get frustrated jack the truck up take the passenger tire off and the filter is right there and you can use the oil filter pliers to get it loose.
by bgwolfpack » Tue Sep 03, 2013 12:55 pm
I use a nylon strap wrench. Works easy.
by Trail X » Tue Sep 03, 2013 12:59 pm
You guys must be putting your filters on too tight.
by Gordinho80 » Tue Sep 03, 2013 1:08 pm
I wasn't due for an oil change, but since I had to drop my pan, guess I have to now. I haven't removed the filter, but I did notice that after taking out the sway bar, Yes, I cut out and removed the front sway bar, there appears to be more room to get at the filter. Maybe I was seeing things, but that's how it looked.
by HARDTRAILZ » Tue Sep 03, 2013 1:09 pm
I don't over tighten it and it comes off by hand without tools every time...
by Moots1288 » Tue Sep 03, 2013 1:26 pm
HARDTRAILZ wrote:I don't over tighten it and it comes off by hand without tools every time...
It depends on how I feel sometimes I do it by hand and sometimes I give it a half turn- full turn with a wrench
by navigator » Tue Sep 03, 2013 3:20 pm
If I need the wrench, mine is an adjustable socket style, kind of like this
http://www.ebay.com/itm/3-Jaw-Two-Way-O ... 71&vxp=mtr
by DirtyBacon04 » Tue Sep 03, 2013 7:24 pm
you could use the K&N oil filter with the 6 point on the bottom if you were really heartset on torquing it down. But like JD and kyle, I've never had to use tools on my oil filter. The Fram filter with the grippy surface makes it easy.
by HARDTRAILZ » Tue Sep 03, 2013 9:25 pm
Decided to grab a fifth matching wheel.
by TBYODA » Tue Sep 03, 2013 9:49 pm
JamesDowning wrote:The key is to wrap it in a plastic bag, and hang it from above, through the handles. Then unscrew the filter, let it drop into the bag, and lower the bag to the ground.
That is very good idea James never thought to to that. I hate that part also. But as of late I have be lazy and having my cuz shop change oil on my cars.
by v7guy » Tue Sep 03, 2013 10:15 pm
DirtyBacon04 wrote:you could use the K&N oil filter with the 6 point on the bottom if you were really heartset on torquing it down. But like JD and kyle, I've never had to use tools on my oil filter. The Fram filter with the grippy surface makes it easy.
Fram! :eek:
by DirtyBacon04 » Tue Sep 03, 2013 11:33 pm
"He uses Fram?!?!"
I'm not loyal to any one oil filter brand; it's always changing.
by v7guy » Wed Sep 04, 2013 12:02 am
after reading on Bob is the oil guy and seeing the filter dissection I vowed to stay far away. Apparently the bypass valve fails regularly and the oil completely bypasses the filter media. Why bother with a filter that has a high probability of not filtering.
by jonbo2002 » Wed Sep 04, 2013 7:06 am
JamesDowning wrote:You guys must be putting your filters on too tight.
knowing me I am the king of over tightening. thats why I went out and got torque wrenches and started looking in the shop manual for everything. I have striped so many bolts back in the day. on a good note though I have gotten really good with a tap and die set :oops:
jonbo2002
