Broken Transfer Case & Upgrade to 4.10 gears
by jonbo2002 » Fri Aug 30, 2013 10:57 am
damn Bill the drive shaft armor wouldn't have helped you there
jonbo2002
by Gordinho80 » Fri Aug 30, 2013 1:55 pm
Here's what I'm thinking as of right now...
Going to replace seal to CV on the "new to me" front diff. Finish rebuilding the spare disco that I have. Replace all the bearings in the rear axle/diff while doing the 4.10 swap.
New fluid in both diffs and TC.
Am I missing anything?
I'm still looking at other options for rear pinion and gear... I've seen them a little cheaper on other sites...
by Gordinho80 » Fri Aug 30, 2013 3:49 pm
Decided to take some pics of how the truck is sitting right now...
by Trail X » Fri Aug 30, 2013 7:40 pm
I think you can get that 4.10 ring and pinion cheaper. Have you checked rock auto? I saw some smoking prices on USA standard 4.10s. Like half what you've got listed.
by dvanbramer88 » Fri Aug 30, 2013 8:00 pm
JamesDowning wrote:I think you can get that 4.10 ring and pinion cheaper. Have you checked rock auto? I saw some smoking prices on USA standard 4.10s. Like half what you've got listed.
Actually, I saw them too. Rock Auto does have ring and pinion sets for the TB 8.6" axle. I was looking around at stuff a few nights ago to satisfy my own curiosity. And they were pretty cheap. Like ~80-$100 IIRC. They also have a bunch of ratios other than the standard 3, making the front diff the limiting factor on the availability various of gear ratios.
by Moots1288 » Fri Aug 30, 2013 9:05 pm
Look into Yukon gears.
by Gordinho80 » Fri Aug 30, 2013 9:25 pm
$129 shipped for the US standards... ZGGM85411
Yukons are much more. Trying to keep costs down as much as possir. Still have to find someone to install it.
by v7guy » Fri Aug 30, 2013 10:10 pm
just throwin this out there, but you can set up gears yourself and save some money. Harbor freight has a dial indicator that's held in good esteem by the hobby machinist guys and it's only $30. Their digital calipers are also surprisingly accurate. Beyond that it's just some compound to check the pattern on the teeth and time. I'm pretty confident you would have no trouble doing it. Plus you could make a real nice guide. lol
hell, some 4:56s might be real nice.
by HARDTRAILZ » Fri Aug 30, 2013 10:18 pm
Man that sucks, but at least you got to upgrade now.
by Gordinho80 » Fri Aug 30, 2013 10:26 pm
Not confident in myself with gearing. Shop offers warranty.
by Trail X » Sat Aug 31, 2013 12:48 pm
Moots1288 wrote:Look into Yukon gears.
My understanding is that USA Standard is Yukon, the difference being that the USA Standard gears do not hit the extremely high standards that the Yukons do. I've read that the specs are still well within working tolerances, and the only expectation is that they will be a bit more noisy than the Yukons. With big tires, I've heard the noise thing is not a big deal.
by Moots1288 » Sat Aug 31, 2013 1:25 pm
So they are basically almost the same. With some specification differences. I can imagine them working the same and Yukon gears just being bought for "name" sake.
by Gordinho80 » Sat Aug 31, 2013 5:33 pm
Today, I managed to get the rear axle off. I then started removing the front differential. I quickly found out that it was not gonna come off easily. So then I started removing the components necessary to take it off: the steering rack and the oil pan. It took some time to get everything off but now the front diff is removed. Since I've got the oil pan and the steering rack, what else should I do while I've got this thing apart?
by Gordinho80 » Wed Sep 04, 2013 8:37 pm
Transfer case has been removed. I need to get a new gasket for between the TC and the transmission. Can't seem to find that listed on RockAuto, may have to go GM Parts or a dealer for that.
Quick question for anyone who has dropped the oil pan on these vehicles. Is there an actual replacement gasket for the oil pan available or am I to use RTV silicone?
by Cable810 » Fri Sep 06, 2013 9:58 am
Have to use the silicone. That's what I did when we swapped diffs.
by dirty anton » Fri Sep 06, 2013 11:11 am
Gordo Get The Silicone Called ( The Right Stuff) It's Good For Your Oil pan Also. This Is The Best Gasket Maker I Have Ever Used! No Chance Of Leaking If Used Properly.
dirty anton
by Gordinho80 » Sat Sep 07, 2013 10:56 am
Any suggestions on how/where I can get the plugs with pigtails from the TC harness? When mine broke, it took out one of the plugs. It's the green and purple 2 wire plug.
If anyone has a junk yard where they can cut one off... No luck in my area...
by Diacom » Sat Sep 07, 2013 11:02 am
You may find a listing for a pigtail on Rockauto, not sure though. Otherwise, check the local dealer and if it's priced a bit high, take the part # and do an internet search. Lots of GM parts suppliers that sell a bit cheaper.
by dvanbramer88 » Sat Sep 07, 2013 11:02 am
Auto parts stores and rock auto sell wire harnesses and pig tails. A quick look on rock auto, I couldn't find what you are talking about, but I'm not exactly sure what to call what you are looking for. If you go into the parts catalogue, under electrical-connectors, look in pig tails, and they have universal connectors.
by TBYODA » Sat Sep 07, 2013 12:38 pm
There is you pull it near me, shoot me a pic of what you need and i'll see when I can get out there take a look think they have a 02 & 03 TB.
