Maint. blues
by boog2006 » Thu Jun 13, 2013 7:39 pm
Need some help!
2006 Trailblazer 4.2 137,xxx miles was throwing P0300 and P0304 codes, just changed plugs with new 41-103s and now it won't run. Cylinder one an 4 showed significant corrosion.
Boog2006 Build Thread
boog2006
by DirtyBacon04 » Thu Jun 13, 2013 8:39 pm
found this video, i know it's for a different engine, but it could give you a direction to go. troubleshooting engine malfunctions is not my strongest point, especially in fly-by-wire system
by boog2006 » Thu Jun 13, 2013 9:21 pm
Thanks I cleaned the CPAS a couple days a go and cleared that code. Then the current issue arose.
I can run this with the intake resonator off right?
boog2006
by boog2006 » Thu Jun 13, 2013 10:02 pm
Ok still need some help. Ditched coil pack four with a new coil...no change
Switched coil 1 with old coil 4 no change...when the engine died this time it actually puffed a little bit of what looked like blue smoke out the throttle body.
boog2006
by boog2006 » Thu Jun 13, 2013 10:16 pm
Answer is...no no you can not.
boog2006
by boog2006 » Thu Jun 13, 2013 10:59 pm
I'm glad I had this little talk with myself...I'll see you tomorrow.
boog2006
by Moots1288 » Thu Jun 13, 2013 11:39 pm
boog2006 wrote:I'm glad I had this little talk with myself...I'll see you tomorrow.
I ran my truck with no intake resonator
by v7guy » Fri Jun 14, 2013 12:53 am
1 and 4 do look pretty rough lol
It's peculiar that it wouldn't run at all after the work. Are you sure you got the coil packs pushed down on the plugs?
The resonator really should be connected so the MAF will measure the incoming air. There's also a major vacuum leak with the front hose (i believe it's the pvc system) on the resonator disconnected. With the TB being disconnected from the intake resonator it may also have trouble controling the idle air mixture. Hook everything up like it's suppose to be and try again.
My WAG is this is the problem.
by boog2006 » Fri Jun 14, 2013 9:04 am
After the resonator was put back on I have no issues.
boog2006
by v7guy » Fri Jun 14, 2013 9:48 am
boog2006 wrote:After the resonator was put back on I have no issues.
sweet!
by djthumper » Fri Jun 14, 2013 4:22 pm
Glad it worked out for you. I had basically the same problem in December and had to replace #1 and 4 coil packs. I found the coil packs on Amazon and got 2 of them for just over the price of 1 locally.
by TuckerJack » Wed Apr 23, 2014 6:24 pm
So, since this is the maint. blues section, figured I'd throw my two cents in... Changed the oil in the ol TB the other day after the previous owner neglected to do it for over a year and a half... I was a little reluctant to add the whole 7qts, mainly because I've never heard of any gasoline engine taking that much. Not even my V6 explorer took that much. So I only added 5.5-6 qts of 5w-30 castrol advanced full synthetic with a fram extreme guard filter for full synthetic oils. I went cheap this time because I just want to get the engine feeling a little better after not having fresh oil for over a year! However, my oil pressure gauge is jumpy now and it wasn't like that before. So while at idle, the pressure reads 40psi, but when I start to drive it jumps to 60psi. Just wondering what everyone else has experienced and if I should take out any more oil.
_________________________________________________________________________________________________________
The only good thing about having a Bachelors of Arts, is having BA behind your name
Tucker Johnson, BA
TuckerJack
by KingBird » Wed Apr 23, 2014 6:32 pm
KingBird
by TBYODA » Wed Apr 23, 2014 6:44 pm
Always check with Manuel :lol: or the read manual. Image
by KingBird » Wed Apr 23, 2014 6:45 pm
KingBird
by TBYODA » Wed Apr 23, 2014 7:25 pm
KingBird wrote:Manuel??? You mean Manuel Labor, the Spanish guy that works in the parts department??? Lol!
Yea that guy. :lol: :lol:
by TuckerJack » Wed Apr 23, 2014 8:55 pm
Just to clarify, I definitely did read the manual haha. But I just wanted to check with you guys to see what your normal pressures and oil levels were. If all else fails, check the dipstick I guess! Haha
First there was one, then there was many
Tucker Johnson, BA
TuckerJack
by dvanbramer88 » Wed Apr 23, 2014 9:20 pm
TuckerJack wrote:So, since this is the maint. blues section, figured I'd throw my two cents in... Changed the oil in the ol TB the other day after the previous owner neglected to do it for over a year and a half... I was a little reluctant to add the whole 7qts, mainly because I've never heard of any gasoline engine taking that much. Not even my V6 explorer took that much. So I only added 5.5-6 qts of 5w-30 castrol advanced full synthetic with a fram extreme guard filter for full synthetic oils. I went cheap this time because I just want to get the engine feeling a little better after not having fresh oil for over a year! However, my oil pressure gauge is jumpy now and it wasn't like that before. So while at idle, the pressure reads 40psi, but when I start to drive it jumps to 60psi. Just wondering what everyone else has experienced and if I should take out any more oil.
Your oil pressure gauge is a lie anyway. You only have an oil PSI switch that looks for about 12 psi. Above 12 psi, the PCM makes up a reading for the gauge to trick the owner that GM actually spent the couple extra bucks on a real pressure sender.
And what would posses you not to believe that Owners Manual for your vehicle when it came to oil capacity? You think the manufacturer is trying to trick you? :|
by DustinC1989 » Wed Apr 23, 2014 9:58 pm
Your V6 didnt take 7 quarts, so a inline 6 shouldnt?
Look at the length of a V6 and compare it to a I6... inline has a tad bit more of a crankshaft that needs to be oiled. Hell even the GM LS motors take 6 quarts, so I'm surprised out I6 doesn't take like 8-9
DustinC1989
by TBYODA » Wed Apr 23, 2014 10:11 pm
dvanbramer88 wrote:And what would posses you not to believe that Owners Manual for your vehicle when it came to oil capacity? You think the manufacturer is trying to trick you? :|
Naw they have random number generator when come to capacity. :lol: :lol:
