Wtb: wheel adapters 6x5.5
by c bausch » Sat Dec 22, 2012 11:52 pm
Looking for wheel adapters 6x5.5 new or used thanks chris 9089663201
c bausch
by HARDTRAILZ » Sun Dec 23, 2012 8:30 am
I have some 1.3 inch adapters i would likely sell.
by c bausch » Sun Dec 23, 2012 9:37 am
Not sure if they would work with my 33's what do you think?
c bausch
by HARDTRAILZ » Sun Dec 23, 2012 10:11 am
Huh ?
by Moots1288 » Sun Dec 23, 2012 11:18 am
by Moots1288 » Sun Dec 23, 2012 11:19 am
You'll be alright
by HARDTRAILZ » Sun Dec 23, 2012 12:25 pm
I used them w 31, 32, 33, 34, 35, 36 inch tires.
by c bausch » Sun Dec 23, 2012 1:39 pm
The width is 1.3 right with the 6x5.5 right?
c bausch
by HARDTRAILZ » Sun Dec 23, 2012 2:19 pm
Yup
by c bausch » Sun Dec 23, 2012 2:40 pm
I thought that we needs a minimum of 1.5 for our trucks . Will it be a issue to go with a wider tire in the future ?
c bausch
by Moots1288 » Sun Dec 23, 2012 3:00 pm
Only if you're going bigger then 35x12.50 which is a pretty big tire
by The Roadie » Sun Dec 23, 2012 3:11 pm
c bausch wrote:I thought that we needs a minimum of 1.5 for our trucks .
With 1.25 or 1.3" thick spacers you may have to grind down the wheel studs a tiny amount, depending on if they hit the back of your rims and prevent full flat friction between the spacer and your rims. Not everybody needs to do this, but if you need to and don't, your studs can fail and the wheel fall off. You have to be prepared to measure and grind if necessary.
by c bausch » Sun Dec 23, 2012 4:28 pm
Got ya
c bausch
by c bausch » Sun Dec 23, 2012 4:29 pm
Hardtrailz whats the going rate?
c bausch
by HARDTRAILZ » Mon Dec 24, 2012 10:17 am
Pm sent
by GONE FISHN » Tue Dec 25, 2012 12:22 am
Do you still have the spacers for sale?
GONE FISHN
by dvanbramer88 » Wed Dec 26, 2012 2:34 pm
GONE FISHN wrote:Do you still have the spacers for sale?
Did you miss the "WTB" part? This is a "want to buy thread." There never was anything for sale in this thread. So, the answer to your question is, No the OP doesn't have the spacers for sale, and he never did. :slap:
by c bausch » Fri Dec 28, 2012 12:13 am
Sorry guys to leave this open for so long i found a set from a guy in my town (who knew)! So at the moment i have what i was looking for , and i can delete the post
c bausch
by HARDTRAILZ » Fri Dec 28, 2012 7:11 am
Or you could have had the decency to respond to my PM days ago....
