Gordinho80's Front End Overhaul
by Gordinho80 » Thu Dec 23, 2010 4:50 pm
So the 4x4 disconnect is starting to give me troubles. I've been meaning to get the truck up on stands so that I can swap out the front suspension components. Looks like Sunday I'll be putting the truck in the garage and getting started!
On the list...
[x]Replace front springs with 88s
[x]Replace Driver Axle
[x]Replace Pass Axle
[x]Replace Driver Upper Ball Joint
[_]Replace Pass Upper Ball Joint
[x]Flip UCAs
[x]Inspect and Rebuild Disconnect
[x]Replace front differential fluid
[_]Replace transfer case fluid
[_]Replace rear differential fluid
I don't think I'll be finished in 1 day... but I'm hoping for the best...
Anyone wanna stop by, feel free...
by Gordinho80 » Wed Jan 12, 2011 10:48 pm
Finally got started on my suspension overhaul. Few weeks ago I did the front springs, they came out great!
Today, I decided I'd start the axles... figure I could probably do the driver side in a few hours if I'm lucky. Well, wasn't lucky...
After fighting the hub assembly with the slide hammer for a good hour, it finally came off the axle. Now, the problem is this. The axle had been clicking for a week now, I found out why when I started working. The shaft came apart. The boot that is inserted into the differential is stuck in place and the rest of the axle is out. I ran out of time and ideas so I put the wheel back together so that I could at least roll the thing. I've essentially got a 3 wheel drive truck right now.
Thoughts on how to get the rest of the axle out?
I also removed the driver side upper ball joint, figured why not...
by NC_IslandRunner » Wed Jan 12, 2011 11:44 pm
This same thing happened to me in oct. last year. I took every thing apart and the axle fell off but that part was stuck in real good, took about an hour to get out with 2-3 guys we use a prybar a hammer and 2 vise grips. pull on it with vise grips while someone uses the prybar, may have to tap on prybar with hammer. It sucked took about 3.5-4 hrs to do both sides.Good luck!
by Trail X » Thu Jan 13, 2011 9:58 am
I've considered investing in one of these from autozone and a slide hammer to help with that pesky inner CV joint.
$20... not bad.
by bdp1978 » Thu Jan 13, 2011 10:42 am
Man, I must have gotten really lucky. Both of my axles took less than an hr. each. 6 lb hammer with a large pickle fork on the back side of the housing...about the 4th whack and they popped right out.
My passenger side came apart like yours, my drivers side came out all in one piece.
bdp1978
by Gordinho80 » Thu Jan 13, 2011 10:46 am
It just sucks that on the driver side, there is no easy way to get a fork or prybar under the truck and between the pumpkin and the shaft...
That puller looks like a good option, JD. I'll call AutoZone and see if they've got one.
by bdp1978 » Thu Jan 13, 2011 11:09 am
They're isnt a lot of room, but there is enough to just grab the edge of the housing. All it takes is one good conection to get it to pop. I did bust a knuckle pretty good when it slipped off on one of my whacks.
bdp1978
by HARDTRAILZ » Thu Jan 13, 2011 11:28 am
I popped my drivers side with a foot long piece of half inch rebar. It slid in and caught enough of the lip to pop it.
by MrSmithsTB » Thu Jan 13, 2011 12:33 pm
If you can't get a solid spot for the rebar, might I suggest wedging something flat and solid between the axle and diff? Try to use something long enough to extend past the frame rail. That should create a point of impact that will allow you to put some strength behind your hit without the worry of slippage.
by Gordinho80 » Thu Jan 13, 2011 12:58 pm
SUCCESS!!! I managed to get it off with the pickle fork, wedged in between cup and the diff from underneath. I hammered it into the cup to wedge it more and noticed it moved a hair... so I whacked at it a few more times and the fawker just slid right off! Now, time to clean the seal and see how it looks. Taking that out should be fun too if I decide to replace it.
by OregTrailBlazin » Thu Jan 13, 2011 1:45 pm
JamesDowning wrote:I've considered investing in one of these from autozone and a slide hammer to help with that pesky inner CV joint.
$20... not bad.
Its what I use! And it works great, it well worth the 20$!! What more of an excuse does a guy need to buy a new tool!!
Johnny Kurz
General Manager
541-474-2879
Wheeler's Off-Road Inc.
Our Vendor Section
OregTrailBlazin
by Trail X » Thu Jan 13, 2011 1:50 pm
OregTrailBlazin wrote:Its what I use! And it works great, it well worth the 20$!! What more of an excuse does a guy need to buy a new tool!!
Maybe you can be of help then... is the thread size a standard among slide hammers? I can't seem to nail that answer down via my googling.
by OregTrailBlazin » Thu Jan 13, 2011 2:25 pm
Most of the slide hammers I've been around have had a larger thread on the slide, then a little adapter that will work with this, and other like attachments.
Edit:.. Looks like McMaster shows the different ends, but I don't see the adapters.. The last time I was in Harbor Freight, they had a kit that had three different adapters and mulitiple attachments.
Edit2:-- Image From HF
Johnny Kurz
General Manager
541-474-2879
Our Vendor Section
OregTrailBlazin
by Gordinho80 » Thu Jan 13, 2011 2:40 pm
Old seal removed... wasn't as easy as I hoped, but I got it out...
New seal in... now to get the new axle shaft in and the rest put back together...
by Zero » Thu Jan 13, 2011 4:36 pm
my seal went bad too. Pain in the ass
by tbangert » Thu Jan 13, 2011 6:07 pm
And I thought I mangled my diff seal trying to get it out... lol
I had a lot of trouble too getting the diff side axle out, thats why I'm being lazy about the other side. Might have to invest in more tools :excited:
tbangert
by fishsticks » Thu Jan 13, 2011 6:52 pm
tbangert wrote:And I thought I mangled my diff seal trying to get it out... lol
Pass side is easy. Unbolt the splined disconnect and pull it with the axle as a unit. Then you can separate them while off the truck.
by Gordinho80 » Thu Jan 13, 2011 7:16 pm
UPDATE:
Driver Side axle replaced! Upper Control Arms swapped! I had to call it a night before I could work on the pass side axle shaft.
Left on the list...
Replace Pass Side Axle Shaft
Replace Pass Side Upper Ball Joint
Open/Inspect/Clean/Re-Grease Disconnect... (order any parts that need to be replaced if worn)
Replace Front Differential Fluid
Replace TC Fluid
Replace Rear Differential Fluid
by Opeth » Fri Jan 14, 2011 2:40 am
$20... not bad.
These are life savers... I picked up one because i didn't feel like prying on the side of the transmission case on my cavalier. One slide on the hammer and they retainer clips just let go. I only paid $12 on my tho... :excited:
by Mooseknuckle » Fri Jan 14, 2011 2:54 am
Hey Mario if you want I'm available sat evening and sunday I can help with whatever you need not to mention I need to replace my fluids as well..
I don't dial 911
Mooseknuckle
