DmccartneyFF2TB wrote:Power trax says they dont make an 8.6 only an 8.5 im sooo confused....
8.5" 28 spline No-Slip - 92-0785-2805
8.5" 30 spline No-Slip - 92-0785-3005
8.6" 30 spline No-Slip - 92-0786-3005
8.5" 28 spline LockRight - 1920
8.5" 30 spline LockRight - 1921
They don't list an application for 8.6" axles, but 4wheelparts shows the 1921 fitting the 8.6" as well. There was an early style 8.6" carrier (with two large windows) vs the later style 8.6" carrier (with one large and one small window). I suspect the 1921 may only fit the early style carrier... which you won't find in an EXT rear axle.
I can tell you from exsperience that the newer 8.6" carrier has a narrower internal width than the 8.5". So if PT says they don't make one, I would trust them.
The No-Slip is pretty slick BTW... much smoother on the street than the Detroit Locker I had in my old K5. Quiet too.
02 TrailBlazer LTZ - 35s, lockers, balls - Gone but not forgotten -
Build
