I am going to be hitting the order button later tonight on a new set of tires. I would like some advice on tire size to order.
I have 2.5" suspension / 3" body lifts and am not afraid to cut. I have the 3.73 gears so I am a bit concerned how the larger tires will fare with them.
I am going to be going with the Tread Wright Guard Dog M/T's but am back and forth on size.
285/70/17 D Rating:$649.45 (5 tires)
Tread Depth: 19/32â€
Meas. Rim Width: 8.5"
Tread Width: 9.1â€
Rim Width Range: 7.5-9â€
Max Load: 3,195 lbs
Outer Diameter: 33.3â€
Max PSI: 65 psi
Section Width: 11.5â€
265/70/17 C rating: $518.50 (5 tires)
Meas. Rim Width: 8â€
Tread Width: 8.75â€
Rim Width Range: 7-8.5â€
Max Load: 2,470 lbs
Outer Diameter: 32.25â€
Max PSI: 50 psi
Section Width: 10.7â€
Is the extra 1" in tire height and .25" in width worth an extra $130 out of the wallet?
