by tsmith1156 » Tue May 24, 2016 12:46 pm
I'll have to grab some and see what I can do cause it doesn't look too good up close right now
tsmith1156
by Fisker » Tue May 24, 2016 12:55 pm
HARDTRAILZ wrote:I dont wash vehicles typically more than a couple times a year, but the stuff is in all the little kits n such people buy or give as gifts. Sits right in the walmart or any auto stores display of washing/waxing/cleaning stuff. I use it for tree sap basically. Sucks parking under a tree.
I would die if I went that long without a car wash lol. I will have to look for it. Especially if I do that badge removal. I would like them gone.
Fisker
by tsmith1156 » Tue May 24, 2016 2:43 pm
I wash mine every so often but that'll probably change once it's lifted and doesn't fit in a drive thru car wash any longer, I'm definitely going to get some so I can put it on and see if it works for me
tsmith1156
by Fisker » Tue May 24, 2016 4:19 pm
Let us know if it does!
Fisker
by 87chevy » Tue May 24, 2016 11:54 pm
Installed new power heated blinker mirrors,changed passenger side cv axle outer boot,changed drivers side wheel bearing hub assembly,changed all four sway bar links and both outer tie rod ends and installed scangauge.
87chevy
by TBYODA » Wed May 25, 2016 10:43 pm
Finally got the my 43" led light bar all wired up that my wife gave me for my B-day. Mounted it on my roof basket.
I also moved my 4" square work lights the back of the basket. I wired it with a three way switch for three modes. Reverse, off, and work.
Work lights
Low beams only
Low beans and led light bar
by v7guy » Wed May 25, 2016 11:43 pm
Looks great Robert! I assume the pic of the driveway is the work lights?
by TB_KSV68 » Thu May 26, 2016 12:55 am
'06 has been sitting for a Month. Key Fob unlocked OK. Fired right up. Ran it up to operating temps. No lights nor codes on Scan Gauge. Odometer reads 60248. Shut down and locked with BEEP. and peed on Left front tire.Good to go until July 4th.....
TB_KSV68
by Jrgunn5150 » Thu May 26, 2016 1:22 am
TB_KSV68 wrote:'06 has been sitting for a Month. Key Fob unlocked OK. Fired right up. Ran it up to operating temps. No lights nor codes on Scan Gauge. Odometer reads 60248. Shut down and locked with BEEP. and peed on Left front tire.Good to go until July 4th.....
That's about what I do with mine too nowadays lol.
by TBYODA » Thu May 26, 2016 1:16 pm
v7guy wrote:Looks great Robert! I assume the pic of the driveway is the work lights?
correct
by tsmith1156 » Thu May 26, 2016 6:55 pm
Got it wiped down and looks great!
tsmith1156
by PROSPHOTO » Thu May 26, 2016 7:05 pm
Got the center caps together and installed today
-Mike
PROSPHOTO
by PROSPHOTO » Sat May 28, 2016 8:31 pm
I think I'm finally done getting ready for the beach... Installed a Hitchgate yesterday and today I installed rear Z71 springs.
-Mike
PROSPHOTO
by Moots1288 » Sat May 28, 2016 10:49 pm
:facepalm: Drove my truck too work.. Still havent worked on it. :oops:
by Jrgunn5150 » Tue May 31, 2016 5:30 pm
Drowned it,
by maricard » Tue May 31, 2016 8:36 pm
Looks bad!
_____LESS IS MORE_____
Ludwig Mies van der Rohe
maricard
by Fisker » Tue May 31, 2016 8:36 pm
How did you do that
Fisker
by Jrgunn5150 » Tue May 31, 2016 8:48 pm
Yeah the engine is wrecked, won't spin by hand or by starter with the plug's pulled.
I was out wheeling, went through a hole, deep, but no problems. Came back the other way, and it ran up and out, then died right there. It was not very dramatic at all, I was at 3500 rpm or so, then nothing lol.
by Cable810 » Wed Jun 01, 2016 1:07 pm
Changed the oil
by BC backroader » Wed Jun 01, 2016 11:22 pm
Washed it so I could tell what colour it is, after running about 80km (50 mi) of muddy logging roads on Sunday. i couldn't get in or out of the thing without getting mud all over my clothes, LOL.
