by tsmith1156 » Tue May 24, 2016 12:46 pm
I'll have to grab some and see what I can do cause it doesn't look too good up close right now
tsmith1156
by Fisker » Tue May 24, 2016 12:55 pm
Fisker
by tsmith1156 » Tue May 24, 2016 2:43 pm
tsmith1156
by Fisker » Tue May 24, 2016 4:19 pm
Fisker
by 87chevy » Tue May 24, 2016 11:54 pm
Installed new power heated blinker mirrors,changed passenger side cv axle outer boot,changed drivers side wheel bearing hub assembly,changed all four sway bar links and both outer tie rod ends and installed scangauge.
87chevy
by TBYODA » Wed May 25, 2016 10:43 pm
Finally got the my 43" led light bar all wired up that my wife gave me for my B-day. Mounted it on my roof basket.
I also moved my 4" square work lights the back of the basket. I wired it with a three way switch for three modes. Reverse, off, and work.
Work lights
Low beams only
Low beans and led light bar
by v7guy » Wed May 25, 2016 11:43 pm
Looks great Robert! I assume the pic of the driveway is the work lights?
by TB_KSV68 » Thu May 26, 2016 12:55 am
'06 has been sitting for a Month. Key Fob unlocked OK. Fired right up. Ran it up to operating temps. No lights nor codes on Scan Gauge. Odometer reads 60248. Shut down and locked with BEEP. and peed on Left front tire.Good to go until July 4th.....
TB_KSV68
by Jrgunn5150 » Thu May 26, 2016 1:22 am
by TBYODA » Thu May 26, 2016 1:16 pm
by tsmith1156 » Thu May 26, 2016 6:55 pm
Got it wiped down and looks great!
tsmith1156
by PROSPHOTO » Thu May 26, 2016 7:05 pm
Got the center caps together and installed today
-Mike
PROSPHOTO
by PROSPHOTO » Sat May 28, 2016 8:31 pm
I think I'm finally done getting ready for the beach... Installed a Hitchgate yesterday and today I installed rear Z71 springs.
-Mike
PROSPHOTO
by Moots1288 » Sat May 28, 2016 10:49 pm
:facepalm: Drove my truck too work.. Still havent worked on it. :oops:
by Jrgunn5150 » Tue May 31, 2016 5:30 pm
Drowned it,
by maricard » Tue May 31, 2016 8:36 pm
Looks bad!
Ludwig Mies van der Rohe
maricard
by Fisker » Tue May 31, 2016 8:36 pm
How did you do that
Fisker
by Jrgunn5150 » Tue May 31, 2016 8:48 pm
Yeah the engine is wrecked, won't spin by hand or by starter with the plug's pulled.
I was out wheeling, went through a hole, deep, but no problems. Came back the other way, and it ran up and out, then died right there. It was not very dramatic at all, I was at 3500 rpm or so, then nothing lol.
by Cable810 » Wed Jun 01, 2016 1:07 pm
Changed the oil
by BC backroader » Wed Jun 01, 2016 11:22 pm
Washed it so I could tell what colour it is, after running about 80km (50 mi) of muddy logging roads on Sunday. i couldn't get in or out of the thing without getting mud all over my clothes, LOL.
