Go big or go home.
by DustinC1989 » Thu Apr 03, 2014 2:32 am
PT-1921 is the part number I have saved for the locker.
EDIT: looking up that part number brought me to this listed as "GM 8.5 8.6 traction devices"
http://completeoffroad.com/i-129828-loc ... pline.html
DustinC1989
by exb5182 » Thu Apr 03, 2014 4:11 pm
Whats the rotation count like on the powertrax no slip? I searched and really dont see much about how many rotations before it grabs
exb5182
Name: Edward R Jr.
by Trail X » Thu Apr 03, 2014 4:30 pm
Zero. Its basically always locked, and only unlocks the faster spinning wheel.
by Trail X » Thu Apr 03, 2014 4:38 pm
Also, regarding the 8.5 vs 8.6 powertrax... viewtopic.php?p=22164#p22164
by exb5182 » Thu Apr 03, 2014 4:49 pm
Yea I already checked my housing I have a mid its 1073 casting with the 2 different size holes so I am told I am good with the ns... yea I researched the lockright and thats what I saw id have to get an 8.5 housing im just glad my 8.6 had the right carrier in It.
exb5182
Name: Edward R Jr.
by DustinC1989 » Thu Apr 03, 2014 9:30 pm
Everything I ever read said the carrier bearings were the only difference between the 8.5 and 8.6...
Guess it looks like I've got more reading to do...
DustinC1989
by exb5182 » Thu Apr 03, 2014 11:44 pm
Yea I read all the same stuff I just know a company that makes money off selling their products will market all applications for their products to sell as much as they can... so I knew something had to be different. Even the 8.6 has 3 separate open carrier designs which is why the no slip listed after 07 requires a new housing. Weird thing is my axle I was told was an 08 and going by the casting number and design of the carrier I don't need a new housing. Im stoked my tires should be in tomorrow I just set up my rear ring and pinion tonight and all my ducks should be in line to finally piece it all together. Im gonna run 2wd for a week atleast bc I know I have no time to tackle that ft diff. Lol I need to break my rear ring and pinion in anyway
exb5182
Name: Edward R Jr.
by DustinC1989 » Fri Apr 04, 2014 12:29 am
My axle is from a 06, so if I have the 1073 casting the 8.5 lockright will work? Or am I reading that wrong?
DustinC1989
by exb5182 » Fri Apr 04, 2014 12:37 am
Lol no the lockright wont work in any 8.6 the the powertrax no slip will.
exb5182
Name: Edward R Jr.
by DustinC1989 » Fri Apr 04, 2014 12:45 am
I see now, So is the 1073 is the only one of the 3 that will accept the no slip? Where is the number located on the carrier?
Sorry for the thread jack, this is info that is new to me
DustinC1989
by exb5182 » Fri Apr 04, 2014 6:26 am
EARLY 8.6 CASE
USE WITH CASE CASTING NUMBER# 0749. WINDOWS ON THE
SIDES OF THE CASE ARE BOTH THE SAME SIZE 3 3/4"
MID 8.6 CASE
USE WITH CASE CASTING NUMBERS# 7875 & 1073.
WINDOWS ARE NOT THE SAME SIZE 3 3/4" & 1 1/2"
LATE 8.6 CASE
THEY ARE MADE TO FIT CASES WHICH WE KNOW AS
40048044 AND THE CASE WILL HAVE A CASTING # 8064..... the late won't work
exb5182
Name: Edward R Jr.
by DustinC1989 » Fri Apr 04, 2014 2:48 pm
Mine says 5166 :scratch:
DustinC1989
by exb5182 » Fri Apr 04, 2014 5:32 pm
Its on the carrier you have to take the cover off to see it
exb5182
Name: Edward R Jr.
by DustinC1989 » Fri Apr 04, 2014 5:57 pm
Mine says 1875 and 5166 near the ring gear bolts... so I'm lost
DustinC1989
by exb5182 » Fri Apr 04, 2014 7:46 pm
Hmm idk im just going off what the rep from powertrax sent me are you sure you have an 8.6
exb5182
Name: Edward R Jr.
by DustinC1989 » Sat Apr 05, 2014 2:16 am
Pulled it off a wrecked 06 EXT and it has 30 spline axles...
Guess I'll email them and see what they have to say
DustinC1989
by exb5182 » Sat Apr 05, 2014 10:20 am
Damnnnnnn I love the look of my tb... I pulled and all nighter to get my 35s on.... poly bushings were no fun I lubed the crap of tge but they're still squeeking. It will be a couple days before I update my build but you can see some pics of the results on instagram. Bucknasty77
exb5182
Name: Edward R Jr.
by exb5182 » Mon Apr 07, 2014 1:47 pm
Build thread updated
viewtopic.php?f=74&t=5089
exb5182
Name: Edward R Jr.
by DustinC1989 » Mon Apr 07, 2014 4:34 pm
Your build thread reminded me of something I was supposed to check...
Looks good by the way, can't wait to get going on mine
DustinC1989
