by galacticfuzz » Fri Feb 14, 2014 7:11 pm
― Antonio Porchia
galacticfuzz
by tarsh » Fri Feb 14, 2014 8:10 pm
Looks good !
Take the path less traveled
tarsh
Name: Nathan Schroeder
by galacticfuzz » Fri Feb 14, 2014 8:20 pm
Thanks. It's not perfect but I think it turned out pretty decent. Sits no higher than my lights and easily removable to switch with my regular load bars. The mounting points stay in regardless of which I have up there.
. Image
― Antonio Porchia
galacticfuzz
by tarsh » Fri Feb 14, 2014 8:46 pm
What did you use to mount it to the rails?
tarsh
by galacticfuzz » Fri Feb 14, 2014 9:58 pm
Same idea as the DIY light bar. Only difference is that there is a front and rear bolt to hold the plates in place so the whole assembly doesn't have to be completely slid out of the rails.
― Antonio Porchia
galacticfuzz
by Norcrosski » Sun Feb 16, 2014 4:36 am
has any body ever broke a sway bar bolt in the frame going down the road 3 in lift with stock end links?
Norcrosski
by The Roadie » Sun Feb 16, 2014 10:16 am
You mean the bolt on the bushing mount bracket? Sure. On the rear. Took the bar off soon after that.
by Trail X » Mon Feb 17, 2014 11:58 am
Did you add edges to all 4 corners since your last picture? I actually really liked it with only corners on the back two corners.
by galacticfuzz » Mon Feb 17, 2014 12:25 pm
I did James. I was on the fence about only having the two but I liked the added corner guards for protection purposes. I'm going to take and put two back up lights between the horizontal bars instead of being down low under the bumper. They also provide some small measure of protection for the front lights as well. Being that it sits only at 2.5" from the base structure, they won't really impede the ability to carry my kayak and whatnot. The center opening will also help in that regards. I also put snap-loc mounting points on each corner for tie down points.
― Antonio Porchia
galacticfuzz
by Aries » Mon Feb 17, 2014 9:59 pm
Picked up this spare GM 8.6 today. My plans are a total rebuild, swap in my 4.56's with Powertrax non-slip for 100% better then new.
Aries
by Trail X » Tue Feb 18, 2014 1:48 pm
Awesome David. I need to go out and pick one up soon. I've got some of the parts waiting at home.
by Moots1288 » Tue Feb 18, 2014 8:17 pm
Good score man!
by Bcchevy » Tue Feb 18, 2014 8:24 pm
Busy today
Low beam socket
Front disconnect fixed with a awd sleeve
Sent From The Unit
Bcchevy
by Regulator1175 » Wed Feb 19, 2014 11:56 pm
I spent an hour in the salvage yard today on a recon mission. It looks like Friday will be a good day of parts collection, I am going back to help a buddy pull an 8.6/G80/GU6 for $95 out the door. I will also be grabbing a pair of spline disconnects for $30 each, provided they come out in one piece. One is out of a Ranier (all wheel drive sleeve!) and the other from a Trailblazer. The Ranier has leather interior that is in excellent shape, so for $100 I will probably pick those up to replace the worn and cracked leather that I have in one of my trucks.
The Ranier is new in the yard and hasn't been picked over to much yet. Anyone looking for anything that I may be able to help with?
by HARDTRAILZ » Thu Feb 20, 2014 7:15 am
I want the disco...
by NC_IslandRunner » Thu Feb 20, 2014 8:49 am
Got a 4.10 front diff?
by boog2006 » Thu Feb 20, 2014 10:05 am
If theres another 8.6 I'm interested.
Boog2006 Build Thread
boog2006
by galacticfuzz » Thu Feb 20, 2014 12:02 pm
Started planning another project (Now the second I will have going since I finished the basket). Ordering up a couple of these bearings. Now to go collect the materials when I get them in to work on a contained awning set up. :bounce:
The other project is frame mounts and extensions for the bull bar that I got as a gift so that it bypasses the radiator mounts. I already have plasma cut the larger components out and they are just waiting to be cleaned up while I wait for the additional tube needed for the bull bar extension. I know the overall thought and feelings about the non functional mall cruiser eye candy. I'm going to try and at least make it less useless. For my vehicle mission, heavy offroading isn't necisarrily going to be the most occuring event at this point. Would be mostly forest service roads and such. :facepalm:
― Antonio Porchia
galacticfuzz
by PapaBear229 » Thu Feb 20, 2014 4:42 pm
I finally got the time and means to chop the anal wart off. Also picked up the tip and some pipe. Now time to weld :thumleft:
PapaBear229
by galacticfuzz » Sat Feb 22, 2014 4:55 pm
Cleaned up the interior and got new tires. 265/70/17 Falken Rocky Mountains.
― Antonio Porchia
galacticfuzz
