by CNCwell » Mon Feb 03, 2014 11:34 am
So I replaced the wheel hub this weekend. The problem is that I am not sure if the hub was the problem. When I pulled the tire the spacer was a bit loose and 5 of the 6 lugs were cross threaded. One was so bad that I had to saw one of the posts off. When I spun the hub after I removed it I didn't hear the normal rattling sound indicating that the bearing was gone. I'm not sure if this is a coincidence or not but I wanted to document this in case anyone else had a similar issue. I did check the other wheel spacers and they seemed fine.
- Attachments
- wheelhub(2).jpg (63.21 KiB) Viewed 25086 times
--Anais Nin
