by KE7WOX » Thu Jan 23, 2014 9:54 pm
mikekey wrote:Slowly putting things back together. Even with the impact wrench pressing these ball joints back in has been a pain in the arse. One day I think I will get a shop press.
Anyways, my pretty parts all ready to get covered in dirt. Right now I look like a mall cruiser. :cheers:
So what was the deal with the Moog arms? were the bushings pressed in? or did you have to do that as well?
KE7WOX
by mikekey » Thu Jan 23, 2014 10:04 pm
Uppers I bought with the bushings pressed in. The lowers I did.
by KE7WOX » Fri Jan 24, 2014 12:33 am
Oh ok.
Was there an option to get the lowers pre-assembled? or do they all come disassembled. I gotta say, that does kinda suck since I don't have a press.
KE7WOX
by mikekey » Fri Jan 24, 2014 8:33 pm
KE7WOX wrote:Oh ok.
You can get a full lower for like $130+. The lower & upper ball joint doesn't need a press. Just a tool you can rent from AutoZone or Advanced Auto or such. May need some heat on it, I needed heat on mine.
I decided to putt around in the garage and cut some new wires. Found some fancy looking cooper core (similar to welding wire) wire, nicer than the cheaper aluminum stuff the audio guys use. However got it at about the same price as the welding wire.
by TBYODA » Fri Jan 24, 2014 11:21 pm
mikekey wrote:I decided to putt around in the garage and cut some new wires. Found some fancy looking cooper core (similar to welding wire) wire, nicer than the cheaper aluminum stuff the audio guys use.
Since you got some extra you want make me set? ;) :happy whip:
by c0a8l0v6i8n9 » Sat Jan 25, 2014 1:47 pm
I got an alignment done finally. They said my tie rods are a little loose. They gave me a quote automatically I found it pretty funny.
c0a8l0v6i8n9
by dvanbramer88 » Sat Jan 25, 2014 2:05 pm
HOLY SHIT! That's beyond rape and even highway robbery.
It also looks like they charge $138 an hour, that's retarded expensive.
by TBYODA » Sat Jan 25, 2014 2:20 pm
dvanbramer88 wrote:HOLY SHIT! That's beyond rape and even highway robbery.
No kidding that is like 3 times on mark up if you get the $60 version on rock auto.
by Moots1288 » Sat Jan 25, 2014 2:33 pm
Almost the same that my boys charges haha
by mikekey » Sat Jan 25, 2014 3:18 pm
I'm not surprised, it seems every place everywhere is committing anal rape without lube. Especially big chains. Not just automotive places. I forgot to mention this, I messed up one of my brand new Moog ball joints installing it, basically I pressed it into a socket, and haven't been able to get it out. So I thought I'd run to O'Reilly's to get a replacement. THEY WANTED $103 for the ball joint. I proceeded to laugh at the guy, for a ball joint. Turns out Advanced Auto across the street want $98 for a ball joint. So I went home and ordered on the internet, again. I get it, you have employees and lights to turn on.
But doubling, and tripling mark up? Just destroying your own business in the long run. America is in trouble.
by dvanbramer88 » Sat Jan 25, 2014 3:33 pm
Yea, i pretty much only buy from the chain auto parts store if I really need something right away. I usually check prices before I order online though. Sometimes I won't be saving much and the convenience is worth it. But I usually end up order from rock auto. Like when the local store wants $300-400 for a $60 radiator for my dads Saturn. Yea, no thanks, I'll wait.
When I did my LBJ's Auto zone had lifetime warranty ball joints for my truck for $25. I was going to get ~$18 all joints from rock auto, and after shipping, It was just a better deal to have a local over the counter warranty and get the parts that day.
Another item I can't save any money on from rock auto is a starter for my truck. Everywhere has a reman for $60 and a new one fore $120. Rock auto's offerings span the same price range.
by The Roadie » Sat Jan 25, 2014 7:24 pm
FINALLY, after my brother came back from Wisconsin for another winter of snow-avoidance, he ground the welds he didn't finish last year (and I was not able to get to), primed and truck bed lined it, and I got it back on today without his help!
Also reinstalled a LED-lit license plate holder that keeps the plate out of the way of rocks, but finally street-legal where my old liftgate position was not. Please excuse the hose spray ... I know my truck normally runs around like Pigpen. I had to get some of the dust off from last weekend.
by Moots1288 » Sat Jan 25, 2014 7:33 pm
The Roadie wrote:FINALLY, after my brother came back from Wisconsin for another winter of snow-avoidance, he ground the welds he didn't finish last year (and I was not able to get to), primed and truck bed lined it, and I got it back on today without his help!
Looks awesome Bill
by mikekey » Sat Jan 25, 2014 7:43 pm
Looks really great Bill!
by RyansTBLS » Sat Jan 25, 2014 8:01 pm
Looks great Bill! The Roadiemobile looks ready to hit the trails again! :flex dirty:
RyansTBLS
by Trail X » Sat Jan 25, 2014 8:19 pm
What are you planning to fill the void on the right side of the swing out with. I know you have thought about it.
by The Roadie » Sun Jan 26, 2014 8:53 am
That's for one or two Scepter cans now I have no roof rack.
by mikekey » Sun Jan 26, 2014 7:07 pm
Moving along on my front end suspension rebuild. Been taking my sweet sweet time.
Got the Fabtechs installed now. My only concern with these is that becuase they are so heavy duty, I could transfer the impact shock of a hard bump to the steering shaft and a bent shaft is probably worse than swapping out a broken TRE on the trail. Guess we'll find out... Fingers crossed.
Passenger side is all back together now.
Drivers side is almost ready for me to start torquing things down. Got my seal in. Just going to leave it open so I can do my alternator and big 6 wiring this evening, then start buttoning it down.
So you won't believe what happened while pressing in my final lower ball joint...
This harbor freight POS started bending along the way.
Anyways, progress...
by Aries » Sun Jan 26, 2014 7:28 pm
mikekey wrote:This harbor freight POS started bending along the way.
Damn dude :awesome: I've seen stripped threads before but not that. Were you using an impact or a four foot breaker bar? I usually use a impact and tap the side of the arm with a ball peen hammer Image .
Aries
by KE7WOX » Sun Jan 26, 2014 7:41 pm
I removed a few inches of snow from the upper surfaces.
KE7WOX
