offroadTB.com • View topic - Longer Brake Lines For 2" Coil Spacer ??
by Aries » Wed Jan 15, 2014 6:31 pm
I have 2" rear spring spacers coming from but before I install them I have to address the rear brake lines. I've spent that last couple day's searching and found a couple threads where others have lengthened theirs but no one got into detail on P/N's or if they had them custom made.
Is there a longer brake line direct replacement?
Aries
by mikekey » Wed Jan 15, 2014 6:39 pm
by Moots1288 » Wed Jan 15, 2014 6:39 pm
by Regulator1175 » Wed Jan 15, 2014 8:50 pm
I lengthened mine. Used a set of stock fronts with an adapter from Napa. Real easy, and inexpensive.
Sent from my SCH-I545 using Tapatalk
by ErikSS » Wed Jan 15, 2014 10:23 pm
I have Z71 springs and Marks 2" rear spacers. The real question is shock extention. The distance your axle is allowed to travel down is limited by your shock. I have the Skyjacker N8030 shocks and feel they are perfect for not needing to change the brake lines.
by mikekey » Fri Jan 17, 2014 4:44 pm
by bartonmd » Fri Jan 17, 2014 4:47 pm
If you're still running stock shocks in the rear, you don't need to do anything, because all you're doing is raising the resting height, not the actual extension.
by mikekey » Fri Jan 17, 2014 5:14 pm
I'm curious about the adapter and his solution. Originally I was told that we have non-standard fittings in the rear. One of the reasons why shops don't just make stainless steel lines.
by Moots1288 » Fri Jan 17, 2014 5:20 pm
by mikekey » Fri Jan 17, 2014 5:21 pm
Well that sounds more complicated. I was fishing to see if there was a Simple DIY method folks here could use if they wanted to make their own lines rather than ordering custom lines.
by Moots1288 » Fri Jan 17, 2014 5:23 pm
by Aries » Fri Jan 17, 2014 6:47 pm
Aries
by Moots1288 » Fri Jan 17, 2014 6:55 pm
by mikekey » Fri Jan 17, 2014 7:21 pm
I was pricing some things after reading a very extensive thread on another forum about building them an realizing that we could probably build front and rears for members here under $100.00 probably sub $80.00 and create a DIY. It's just I couldn't recall which connector on our trucks is the problem connector. I was thinking it was the rears. Staring at the fronts, they looked normal.
by v7guy » Sat Jan 18, 2014 12:17 am
Yeah, it's the rears, they have an odd fitting size and a through bolt in the fitting for mounting... 1/2 20. On top of that the fitting is also a T to go to the other side on 04 and up.
by Moots1288 » Sat Jan 18, 2014 12:56 am
by Regulator1175 » Sun Jan 19, 2014 2:59 am
