But sas had been done already can't wait to see a long travel suspension done.NC_IslandRunner wrote:JamesDowning wrote:NC_IslandRunner wrote:Would they be stronger if you just cut them out of a single piece of steel and powder coated it? save on buying the Johnny Joints and no welds that can break?
Like make the whole thing 1" plate? 3 issues I see with that.
1: it would be very heavy, as is each side prob weighs 15 lbs. Solid 1" plate would easily double that
2: you still have to weld on some sort of mounting bushing to the plate. You can't just have a hole drilled in that a bolt goes through.
3: the pinch plate is welded on separately so the angle can be set on two axis, to make the ball joint angle correct. If it was 1 solid flat plate, it would likely be off more than the stock arms are, maybe slightly better.
A friend of mine said he could make it in one piece with bushings, or with adjustable johnny style joints but the pinch plate would be build it and cut at the angle you wanted, the whole thing wouldn't be 1" thick. I knew he had a shop that customized cars and truck for show, but I just found out he bought another shop that builds custom suspensions. If I thought it was worth it I'd put him to making a long travel suspension but a SAS would be cheaper than a full custom IFS, plus my wife would kill me!
Moots1288 wrote: But sas had been done already can't wait to see a long travel suspension done.
Just got to blast some speed bumps!JamesDowning wrote:Yeah, mainly looking for cracks in the welds. So far so good.
The official Moots testing methodWahugg wrote::raspberry: The official Moots testing method
JamesDowning wrote:I did run solid core .030 with gas. I've also ran flux through it. The flux is a bit messier, but does burn hotter. I was on the fence whether i needed flux on this, but the 211 seemed to do well on the pinch plate with the voltage turned all the way up and the wire speed turned down a little. I had enough plate cut for 4 UCAs and used two of the sets as practice to get the heat right.
Pardon my ignorance but how does less current make the filler hotter? Sound backward. Just trying to understand.bartonmd wrote: But yes, if you are on the hairy edge, lowering the wire speed actually lowers the current output, but makes the actual filler hotter, so it will penetrate better. Eta: More specifically, you adjust voltage with the dial, and the wire speed changes the current. More wire speed = more current. At the edge of a welders capability, it will usually have voltage but run out of current capacity, so you lower then wire speed in order to get the wire temperature hotter to penetrate deeper.
