by Chango » Fri Jan 10, 2014 8:03 am
Regulator1175 wrote:
Chango wrote:I have had the same problem here. I bet I've called 30 junk/parts yards and very few actually know what they are tying to sell you, just "what the computer shows". I guess there is no "test" to see how much you actually know before you start taking calls at a junk/parts yard.
Check out
Morris Rose Auto Parts
2129 East Michigan Avenue
Kalamazoo, MI 49048
Toll-Free: 800-345-0123
Phone: 269-345-0123
Fax: 269-345-0002
Not sure what your looking for, but they have an SS rear end with 70k on it for $330. That is where I got mine.
Thank you! I will give them a shot.
Chango
by mikekey » Fri Jan 10, 2014 8:18 am
Check out
Kalamazoo, MI 49048
Phone: 269-345-0123
Fax: 269-345-0002
Holy hell! Wish I lived near by, I would be all over that! That is an excellent deal. That's the average price of an 8.6 rear in this state!
by v7guy » Fri Jan 10, 2014 9:59 am
TBYODA wrote:So tonight on the way to a Cub Scout den meeting my TB started & ran a little rough and I thought to myself sounds like it is misfiring. As I was driving the CEL came on & flashed. Once I got to the meeting I whipped out my ELM27 scanner. Sure enough p0304. Thanks this site and GMTNATION I knew to try and swap with nearby coil pack. So after I got back home I pulled the TB in the garage and got to work. I think I may have dodged a bullet. Upon inspection the wire to the pack seemed a little loose, also there was some water droplets on the end of the pack more then I would think should be if any. The electronic service tech in me smelled the end for the coil, yup burnt electronics. But I swapped the pack anyway and cleared the code and went for about a 10-12 min drive no codes and ran fine the whole time. With my luck it will come back at some point might as well pick one up as spare. Looking on rockauto I see six different models for my 08, any real difference between the others and the ACdelco D1935E?
Generally you're looking at cylinder 4. Water drips down from the cowl, falls onto the coil and eventually ruins it. It's pretty common. I seem to remember that the ACDelco is the way to go, the truck is finicky, like with the spark plugs if I remember correctly.
by Opeth » Fri Jan 10, 2014 10:22 am
Hopefully that's all it is.... My P0306 turned into a full head replacement due to a stuck valve @ 74k miles which I swear was caused by loose intake manifold bolts.
by HARDTRAILZ » Fri Jan 10, 2014 10:41 am
Planning on redoing the front end tonight. Did get a P0014 code this week once, but cleared it and has not come back. Hoping its just due to needing an oil change.
by TBYODA » Fri Jan 10, 2014 11:59 am
Opeth wrote:Hopefully that's all it is.... My P0306 turned into a full head replacement due to a stuck valve @ 74k miles which I swear was caused by loose intake manifold bolts.
Because of your mishap that you posted awhile ago I went and tightened the intake manifold bolts and some were quite loose especially the bolts closer to back of the motor. I am at just over 71k so I hope I headed off a head replacement. :angry whip: I do have power train warranty so I am covered if anything major happens :mrgreen: I did place order for the ACDelco part and new a plug just in case.
by mikekey » Fri Jan 10, 2014 2:00 pm
Does anyone happen to have a part number for the lower strut bushing on the lower control arm? Looking at Rock Auto's site, but can't find a Moog or other replacement. Figure I might as well replace mine.
Nevermind, think I found it: http://www.rockauto.com/catalog/moreinf ... cc=1432188
Also I think MOOG K200270 ... not 100% sure
This guy though
------ UPDATED ----
MOOG Part # K200272 Front Lower Rear $10.86 this is the big bushing at the rear or the control arm bracket
MOOG Part # K200271 Front Lower Front $10.92 this is the small bushing at the front of the control arm bracket
MOOG Part # K200269 Front Upper $15.17 this is for the upper control arm, 2 in a box.need 2 boxes to do both sides
MOOG Part # K200270 Front Lower At Shock $16.33 this is the lower mount for the shock that goes through the lower control arm
:thumleft:
by Moots1288 » Fri Jan 10, 2014 3:17 pm
mikekey wrote:Does anyone happen to have a part number for the lower strut bushing on the lower control arm? Looking at Rock Auto's site, but can't find a Moog or other replacement. Figure I might as well replace mine.
This guy though
------ UPDATED ----
:thumleft:
its the front lower lca outter
by mikekey » Fri Jan 10, 2014 3:33 pm
Regulator1175 wrote:There is also this one available that I looked at.
That is a way better price than the one listed on DB Delectrical's website. Guess I'll have too pick this one up instead. :thumleft:[/quote]
Just showed up, I'll be combining this with my big 4 wire upgrade, the new battery and new inverter. Eventually a second battery will go in the back. Should help out when I get around to getting that Engel.
by mikekey » Fri Jan 10, 2014 5:49 pm
Geez... can't believe I'd been riding around on this since TECORE. :wallbash:
by Moots1288 » Fri Jan 10, 2014 6:47 pm
mikekey wrote:Geez... can't believe I'd been riding around on this since TECORE. :wallbash:
already they weren't new.. time to replace em!!
I've been stalking to install my lca outer bushings Image
Must be nice to be in fl
by mikekey » Fri Jan 10, 2014 6:50 pm
The garage is helpful, doubly helpful is it's back in the high 70's this weekend.
by Moots1288 » Fri Jan 10, 2014 6:55 pm
mikekey wrote:The garage is helpful, doubly helpful is it's back in the high 70's this weekend.
It is going to be in the 40s 50s which is fine but I got no time right now. Got some other things I need to get done. Hopefully everything goes alright
by HARDTRAILZ » Sat Jan 11, 2014 4:35 am
Radflos are on.
by TBYODA » Sat Jan 11, 2014 10:26 am
HARDTRAILZ wrote:Radflos are on.
Cool!!!!
by NC_IslandRunner » Sat Jan 11, 2014 12:25 pm
Mine looks like that for over a year, a lot less squeaking after I replaced them.
by mikekey » Sat Jan 11, 2014 12:58 pm
You know the drill Kyle, you big ol' picture whore. :poke:
:cheers:
by HARDTRAILZ » Sat Jan 11, 2014 1:32 pm
Working today...but they will be available later
by mikekey » Sat Jan 11, 2014 5:39 pm
Got the lowers of the truck today, still waiting on SummitRacing to deliver the back half of the lowers. Called them yesterday and they said they had just been shipped, placed that order back on Dec 3rd!!!!! :hissyfit:
Lowers are on the bench, ready to press out after dinner.
Planning on running the spindles over to my father in-law's shop to sandblast and paint
And here is brand new red Moogs upper control arm, :idea: because why not. Too much??
by DustinC1989 » Sat Jan 11, 2014 5:46 pm
I like them, painting mine orange when I take the front apart
DustinC1989
