TBYODA wrote:What size did you get? BTW 30.6" is the max without spacers.
Opeth wrote:Are we admiring the bondo'd car or what appears to be a cummins 6BT?
Aries wrote:Then I snapped one of Gary's $200 Matco 3/8 drive ratchets trying to loosen the fill plug, after a little heat I got it out and filled her up.
Then a quick test drive to make sure everything was working properly before heading home to beat the snow.
I will say "Damn the TB ride nice" [/size]
Chango wrote:Opeth wrote:Are we admiring the bondo'd car or what appears to be a cummins 6BT?
I was looking at that too...does it have twins on it?
dvanbramer88 wrote:If it were me, the FIRST thing I would of done would have been to take the fill plug out. Did you regear the front yet?
DustinC1989 wrote:Ordered new tires, hoping they fit okay... went with a really odd size due to the stupid 18's.
Guy at the shop claims they will clear the ball joints but might rub on fender liners.
Hope that's all they rub, cause I'll keep them and pull liners if that's all
Beamer wrote:DustinC1989 wrote:Ordered new tires, hoping they fit okay... went with a really odd size due to the stupid 18's.
I fit 265/75-16 Yokohama Geolander ATS's on mine without spacers, but did a little grinding on my ball joints. Check out my build thread, it is documented there.
Been running this way for a few years and no issues. I do have a shiny non-rusted spot on the ball joints that I blame on entering my driveway (wheels turned while transitioning from street to driveway).
Details were you pick up and $$ if you don't mind.Regulator1175 wrote:Today I installed my new 200amp alternator
Regulator1175 wrote:Today I installed my new 200amp alternator, new starter, outer tie rods, green filter, and gator belt. Unfortunately the tension pulley has not arrived yet and the idler pulley was the wrong size, so I still have a lot of noise. I then got it in to a buddies shop for a free alignment.
Here is the final product.
We left some positive camber since the coilovers only have 100 miles or so on them. We were thinking that as they settle a bit the tires will come into correct specs.
It was great timing as well. I pulled 6 cars out this evening, and got my wife to work safely. She was the only CNA to show up for third shift!
TBYODA wrote:Details were you pick up and $$ if you don't mind.Regulator1175 wrote:Today I installed my new 200amp alternator
Regulator1175 wrote:There is also this one available that I looked at.
