by Trail X » Fri Dec 27, 2013 5:45 pm
One piece closer to putting the puzzle together.
by Aries » Fri Dec 27, 2013 6:27 pm
Drove out scouting my secret deer stand today. Season opens up again in a couple weeks :excited: I got to be ready to take them down, my goal is to fill all six tags!Image
Aries
by ErikSS » Fri Dec 27, 2013 6:57 pm
JamesDowning wrote:One piece closer to putting the puzzle together.
Are you changing gear ratios?
by djthumper » Fri Dec 27, 2013 7:12 pm
Nice!
by Regulator1175 » Sat Dec 28, 2013 12:05 am
I replaced both front wheel bearings on the Bravada today. I went with the $80 pair of Detroit Axle wheel bearings from Ebay with a one year guarantee.
by ErikSS » Sat Dec 28, 2013 12:16 am
Regulator1175 wrote:I replaced both front wheel bearings on the Bravada today. I went with the $80 pair of Detroit Axle wheel bearings from Ebay with a one year guarantee.
Nice! They had been making noise for a while... Sound better now?
by dvanbramer88 » Sat Dec 28, 2013 12:46 am
2 new axle seals and a set of brake shoes on the rear of my truck. I stopped working around 11pm. The driver side wheel cylinder is leaking brake fluid, so i should replace that too. The driver side is ready to go back together, just gotta wait for the parts store to open to grab a wheel cylinder. $11 part holding up the whole operation. My first experience with axle shaft removal went very smoothly.
Also took the grandparent's Envoy to get inspected this morning.
by Trail X » Sat Dec 28, 2013 12:46 am
Yeppers, going the 4.56. Got a decent deal on the nitros for the front. Seems nitro has a real good following, better than even yukon it seems.
by Regulator1175 » Sat Dec 28, 2013 1:35 am
Yes, definitely sounds better. Both sides were shot. I can finally listen to my radio at a reasonable volume!
by mikekey » Sat Dec 28, 2013 10:27 am
You going up in tire size James?
by Aries » Sat Dec 28, 2013 11:48 am
JamesDowning wrote:Seems nitro has a real good following, better than even yukon it seems.
All depends on what flavor cool aid they like. :bow down:
Aries
by The Roadie » Sat Dec 28, 2013 2:01 pm
Been a busy week working with my brother's help.
Steering rack popped the casting ring that held in the tensioner bolt while installing new inner tie rod end. Must have been pre-weakened by trail abuse. Have to measure the old rack to see how much it's bent, but my digital calipers need a new battery. Anyway:
1) Steering rack. Reman from Rockauto had the lowest price at $310 including the core charge because my core is toast.
2) Took three tries and three $20 seals to successfully put in the fluid lines. My brother messed up the first two times, and I did it the third time by getting a better angle on the final insertion tapping by pulling the driver's side CV shaft.
3) New inner and outer tie rod ends from spares stock
4) New Timken hubs from spares stock
5) Changed coolant and PS fluid.
6) Installed silicone Jettstream radiator hoses I've been carrying as spares for about 4 years. Thank goodness I didn't try to install these on the trail, because the thermostat tube had a lip at the end that the stiffer reinforced silicone hoses would NOT fit over. We had to remove the thermostat and cut off the lip.
7) Stainless worm drive hose clamps on radiator hoses and brake boost vacuum hose.
8) Experimenting again with rebuilt disconnectable anti-sway bar links on the front. Rear has the links and bar gone for years.
9) Designed a better way to insert the locking pin for the front winch Multimount so I can get at it more easily with Mike's skid plate in place. Not drilled yet, but the pin will go in vertically instead of horizontally.
10) Installed Gatorback belt (new) I had been carrying for 6 years as a spare. Finally decided it was crazy to be carrying spares of higher quality than the parts on the truck.
11) New Procomp Xtreme MT2 LT285-75/16 tires that were a combined family Xmas gift. List $295 each - got from local Discount Tire for $225, plus the usual install/balance/tax BS fees that brought them right back up to $300 ea out the door.
12) Alignment at the local tire store that isn't scared to work on the Roadiemobile. 4 out of 6 nearby shops refuse to touch it, and one of the remaining two is incompetent because they told me I didn't have a camber or caster adjustment.
13) Removed custom rear bumper so Bud can finish grinding it, and then we'll discuss powder coat or Rhinoliner.
14) Lots of more fix-ups planned to reduce weight and install water storage tank.
by c0a8l0v6i8n9 » Sat Dec 28, 2013 4:39 pm
Installed two 27w Tuff led lights today on my pushbar.
I also came across this picture of a TB.
c0a8l0v6i8n9
by Aries » Sat Dec 28, 2013 5:54 pm
c0a8l0v6i8n9 wrote:I also came across this picture of a TB.
I bet that won't show up on CarFax
Aries
by DirtyBacon04 » Sat Dec 28, 2013 7:29 pm
I wonder if he has a hilift... and a front end loader?
by ErikSS » Sat Dec 28, 2013 8:10 pm
Is that a New York plate?
by Moots1288 » Sat Dec 28, 2013 9:36 pm
ErikSS wrote:Is that a New York plate?
maybe.. but the beach is to clean may be a beach out east long island.
by ErikSS » Sat Dec 28, 2013 9:47 pm
So what theories do we have? Photoshop? Tide? Tsuami? Total Jacka$$?
by KE7WOX » Sat Dec 28, 2013 11:17 pm
It could also be an Ohio DUI / restricted privileges plate.
KE7WOX
by DirtyBacon04 » Sun Dec 29, 2013 5:13 am
I thought quick-sand was only a myth...
