offroadTB.com • View topic - RadFlo Group Buy
RadFlo Group Buy
by bartonmd » Sat Nov 23, 2013 5:55 pm
by KE7WOX » Sun Nov 24, 2013 8:48 pm
So what's the final verdict on the factory pre-set perch position? is it the same as stock height or not? I have yet to take measurements, but mine are not all the way to the top, so I don't know if they are pre-set to some lift, or if they are at stock and these can be, in fact, used to lower the truck.
KE7WOX
by ErikSS » Sun Nov 24, 2013 9:38 pm
I had marks 3".... And seriously collapsed springs. All I can tell you is that the Radflo at factory preset was the same as my 3" lift and collapsed springs. Sorry the information is really useless. I threaded mine down almost to the bottom. 3 1/4" of thread above my collar. I didn't gain any vehicle height after 3" so I stopped.
by firefox2501 » Sun Nov 24, 2013 9:47 pm
Erik - How bad is the angle on your CV joint?
firefox2501
by ErikSS » Sun Nov 24, 2013 9:51 pm
I don't find it too bad. A lot! But no bind.
by TBYODA » Sun Nov 24, 2013 9:55 pm
by firefox2501 » Sun Nov 24, 2013 9:56 pm
Hope it doesn't cause any problems. I remember someone (v7guy I think) had problems with the angle from the '89s...
firefox2501
by Moots1288 » Sun Nov 24, 2013 10:07 pm
Mine looks the same
by v7guy » Sun Nov 24, 2013 11:52 pm
by HARDTRAILZ » Mon Nov 25, 2013 12:33 am
by ErikSS » Mon Nov 25, 2013 7:28 am
by HARDTRAILZ » Mon Nov 25, 2013 7:40 am
Great info!
by firefox2501 » Mon Nov 25, 2013 9:22 am
Mine are being delivered today but I probably will not be able to install them for a while. Weekends are pretty booked up for a while.
firefox2501
by mikekey » Mon Nov 25, 2013 10:18 am
I'm not going to install mine for awhile. I have a bunch of plans for the ol' girl and I plan a big project weekend. Got upper and lower ball joints to replace, Fab Tech tie rod ends, new rear end, new rear shocks, springs, bushings all over the place, and some other little secretive projects. Although I am tempted to just shove them in there and then come back and adjust them later when I do the diffs. But I'd rather do everything all at once.
by Trail X » Mon Nov 25, 2013 10:47 am
Mine come today, but when I install them, I'm doing a front end overhaul. It will be a few weeks for me too.
by Aries » Mon Nov 25, 2013 11:34 am
Aries
by TBYODA » Mon Nov 25, 2013 12:22 pm
I got mine today. If any one cares they are 18 3/4" from end to end and the upper spanner fits them. :mechanic:
by TBYODA » Mon Nov 25, 2013 1:07 pm
I think maybe I found the external bump stop looks like the left one.
http://m.eibach.com/products/770051_with_ring.shtml
http://m.eibach.com/products/770051_without_ring.shtml
I also took close up picture of the bottom, does not look like any small rubber stop.
by Aries » Mon Nov 25, 2013 2:41 pm
Just came home to a box on the porch!! I GOT UM!!!! :woot:
Aries
by dvanbramer88 » Mon Nov 25, 2013 2:54 pm
