This what I plan to run once my new radflo's come in. Search on amazon for them, they are currently $44.38/each and fee two day shipping if you have primeErikSS wrote:I bought the Skyjacker N8030.
navigator wrote:unless you can press the spacer/bushing out of your factory shocks.
Mike that is really good idea. What is between the left washer and shock, is the the steel sleeve?firefox2501 wrote:I have the Skyjacker 8030s, too. But instead of a bunch of washers on the bottom shock mount, I picked up a couple nylon spacers at the local hardware store. Been running them for a year with no problems.
The spacers are 1/2" tall with an inside diameter of 1/2". Notice the single washer between the spacer and the shock.
that's probably the steel sleeve that goes through the bushingTBYODA wrote:Mike that is really good idea. What is between the left washer and shock, is the the steel sleeve?firefox2501 wrote:I have the Skyjacker 8030s, too. But instead of a bunch of washers on the bottom shock mount, I picked up a couple nylon spacers at the local hardware store. Been running them for a year with no problems.
JamesDowning wrote:Nice solution Mike. I was going to post up and say that grade 8 washers aren't exactly necessary here. Your nylon more than proves that.
