offroadTB.com • View topic - How to upgrade to EXT/SS Brake Upgrade
by Trail X » Mon Sep 16, 2013 10:25 am
Same force at a larger radius from the hub center has to make a difference. Granted, it's numerically only ~7% more stopping torque. But I could see it making a palpable difference.
by HARDTRAILZ » Mon Sep 16, 2013 10:29 am
Kinda wish I needed brakes so I could more easily justify this.
by jonbo2002 » Mon Sep 16, 2013 10:32 am
lol thats exactly why I did mine, they were trashed and grinding to stop
jonbo2002
by Gordinho80 » Mon Sep 16, 2013 11:19 am
I've had a set of EXT front rotors sitting in my garage for over a year now. My rotors have not needed replacing yet... so I too, can't justify doing this swap yet. Once these rotors are gone, or the pads, I might get the brackets and upgrade. As long as my 16" H3 wheels clear the rotor/caliper.
Mario -
by mikekey » Mon Sep 16, 2013 12:16 pm
by HARDTRAILZ » Mon Sep 16, 2013 12:32 pm
All my vehicles get ceramic and I got no reason to switch em.
by JorDaneeKey » Mon Sep 16, 2013 12:49 pm
As told by the other half:
JorDaneeKey
by bartonmd » Mon Sep 16, 2013 1:30 pm
Most are aware that the SWB 5.3L gets the EXT/SS brakes, as well. Some have heard this already, but doing a panic stop from 65mph with a 6500# trailer behind mine, I actually turned the stock tires on the wheels. Like, tires were out of balance the rest of the way home, there was little rubber shavings around the rim, and the dent in the tire from the wheel weight was ~180 degrees away from where the wheel weight was located on the wheel.
by Blazintrails03 » Mon Sep 16, 2013 3:38 pm
Blazintrails03
by TBYODA » Mon Sep 16, 2013 4:11 pm
by mikekey » Mon Sep 16, 2013 4:28 pm
by Blazintrails03 » Mon Sep 16, 2013 4:46 pm
Oh ok. Thinks for clearing that up. Will wait til I need pads to upgrade to this then. Excellent write up too
Blazintrails03
by bartonmd » Mon Sep 16, 2013 6:54 pm
by v7guy » Tue Sep 17, 2013 1:52 am
Yup, tires rotating on the wheels happen, not often on passenger vehicles on the road, but as Mike posted, given the right circumstances it'll happen. Drag cars do it, road racing cars are known to do it and I've read of it happening off-road fairly frequently as well.
by mikekey » Tue Oct 01, 2013 1:12 pm
I'm starting to wonder if I can fit these Camaro Brembo's in there.
by Moots1288 » Tue Oct 01, 2013 1:49 pm
by jonbo2002 » Tue Oct 01, 2013 2:30 pm
jonbo2002
by mikekey » Tue Oct 01, 2013 2:42 pm
Nope, I don't have the problem, but I have HEAVY ARSE tires. The Nitto's weight 60lbs each not mounted.
What I know is I saw a huge improvement putting 4 pistons on the Vette in all four corners, like snap your neck stopping.
I know that the vast majority of your stopping is the front wheel, however ... why can't I improve it. Anyways, you can pick up these calipers for cheap from guys switching to the even bigger ones. So I'm still researching ideas for better stopping. Maybe it's pointless, but with a kid on the way I think about it. It would be nice to have a lifted SUV on fat tires that can stop like a car.
by JorDaneeKey » Tue Oct 01, 2013 3:07 pm
JorDaneeKey
by Karo » Tue Oct 01, 2013 3:23 pm
I had some similar ideas for the front brake system, but after checking the brake force on a computer controlled machine with new brake pads and new rotors in front and the rear there really was NO REASON to change the factory system. The result was more then impressive it was even better than most stock cars are.
This was not compared to high brake systems like ceramic brake systems from porsche. But the results are much better compared to most stock cars. I have tested that with a german TÜV engineer and he had really the knowledge as he is checking cars every day for the reason if they are german street legal.
Changing the caliper for a 4 or 8 piston brake caliper is possible. I really like the idea to install some brembo 4 piston calipers in the front, where could i found those calipers pictured? For which diameter rotors are these calipers made?
For reference here are some Brembo Kits, look for the prices...
Karo
