by ErikSS » Sun Sep 29, 2013 8:03 pm
Mr. Barton. They're picking on your oil pan skid!!! hahahaha
by HARDTRAILZ » Sun Sep 29, 2013 8:45 pm
I washed mine...
Well it rained, close enough.
by RyansTBLS » Sun Sep 29, 2013 8:48 pm
In which case I washed my truck too! :cheers:
RyansTBLS
by Cable810 » Mon Sep 30, 2013 9:32 am
Washed mine too lastnight
by dvanbramer88 » Thu Oct 03, 2013 2:44 pm
Fixed my broken tailgate hinge and cleaned the interior. Got all the dust and dirt out from TECORE. I sprayed cleaner on my dash and it literally made mud... Alsoo hand cleaned all the windows.
poor-boy bench vise
by jrSS » Thu Oct 03, 2013 3:26 pm
Bought the rubber inserts for the cup holders today from ebay. Paid $30 for all 6. Can't find a better deal.
jrSS
by dvanbramer88 » Sun Oct 06, 2013 9:57 pm
I hit 268,000 miles going to TECORE. Tonight I hit 269,000 miles. Lot of long highway trips are adding up.
by Cable810 » Mon Oct 07, 2013 10:12 am
Drained and cleaned the Rear diff. Found water and dirt in it.....
by boog2006 » Mon Oct 07, 2013 10:08 pm
P0128...changed thermostat...it sucked...twice
Boog2006 Build Thread
boog2006
by DirtyBacon04 » Tue Oct 08, 2013 6:32 am
I keep getting that code on an irregular basis. I have had parts in hand for months, but lack the effort to replace. Also, not really seeing the immediate need, as my temps are acting normal.
by boog2006 » Tue Oct 08, 2013 10:57 am
Yeah I've been fluctuating between top dead center and two clicks left. Figured it was time.
boog2006
by v7guy » Wed Oct 09, 2013 1:25 am
I've gotten that code in the last couple weeks, temp showed a few clicks to the left for a couple days and then started acting normal again. Kinda strange. It's irritating cause I just replaced it a year ago or so.
by KE7WOX » Wed Oct 09, 2013 7:48 pm
Finally had a headlight die on me sometime this week (I'm guessing yesterday, but US-33 has lights so I didn't notice until I got home), replaced both low beam bulbs with Sylvania Ultras.
KE7WOX
by Regulator1175 » Sun Oct 13, 2013 2:53 am
Today I got most of my truck back together. Thank you Eric for contributing your day to helping me with the re-assembly.
The list of new parts:
Front upper and lower heavy duty control arms
Upper and lower ball joints
SS Rotors (all 4 corners)
Calipers (all 4 corners)
Brake pads (all 4 corners)
Extended brake lines (all 4 corners)
Rear upper and lower adjustable control arms from Massive
SS rear axle with custom U joint
Rear Skyjacker springs
Rear Skyjacker shocks
Alignment set up for tomorrow pending successful assembly of my new brake lines.
My original transmission is now bolted up to my engine stand and I will start my tear down and overhaul on that tomorrow. With any luck I will be able to get it rebuilt and installed in the next few days and ready to wheel next weekend. If not my current Tranny will survive, it just wont be happy with me. The Radflo's are the last part left in the rebuild and I will have an entirely new suspension set-up.
by Trail X » Sun Oct 13, 2013 4:32 pm
Heavy duty control arms? Do tell us more about these. I haven't heard of HD versions before.
by Opeth » Sun Oct 13, 2013 5:12 pm
Hacked off that hideous anal wart of a resonator.
by HARDTRAILZ » Sun Oct 13, 2013 10:12 pm
Took some junk out and dropped it in barn at land for winter storage.
by Sugar16 » Mon Oct 14, 2013 9:14 am
Built a light bar this weekend for the top, im still waiting on my switches to come in the mail so this week i will have some better pictures of the finished product, its raining out now so i only have a couple of pictures from when i was building it
Sugar16
by Trail X » Mon Oct 14, 2013 4:32 pm
I like the LED lights, but your flat bar leaves a lot of rigidity on the table. I would highly recommend switching to a square tube.
by Sugar16 » Mon Oct 14, 2013 4:44 pm
JamesDowning wrote:I like the LED lights, but your flat bar leaves a lot of rigidity on the table. I would highly recommend switching to a square tube.
Yeah, I found that out this weekend when I drove it, I heard something that sounded like my hatch was not closed all the way. When I went to get the square tubing I was having a hard time finding it but i found the flat bar and I didn't think there would be an issue but that was probably because I was just excited about getting it done. :facepalm:
The LED's are real bright, once I get the switches I will get some pics of them on and off
Sugar16
