offroadTB.com • View topic - Fixing my steering today...
by TBYODA » Tue Sep 24, 2013 8:30 pm
Ok know I am new to this stuff but they look awful simple, Could not someone that can welder real good make some? Just need to come up with the two end pieces. That is awful a lot cash for that.
by mikekey » Tue Sep 24, 2013 8:36 pm
by ErikSS » Tue Sep 24, 2013 9:31 pm
I found another option from Rough Country. It's a sleeve that goes over the weak part of the 2500 tie rod end.
Input everyone???
http://cdn.roughcountry.com/media/catal ... -small.jpg
by Moots1288 » Tue Sep 24, 2013 10:31 pm
That looks like it should work .. Def will strengthen the long weak part of the inner rod
by fishsticks » Tue Sep 24, 2013 10:32 pm
by Trail X » Wed Sep 25, 2013 10:28 am
by mikekey » Wed Sep 25, 2013 10:46 am
by HARDTRAILZ » Wed Sep 25, 2013 10:57 am
by HARDTRAILZ » Wed Sep 25, 2013 11:00 am
by mikekey » Wed Sep 25, 2013 11:10 am
That Fabtech set looks interesting.
So does the Rare Parts, which includes at least one measurement in their photo
If we can do an HD TRE upgrade, it stands to reason we could use one of these upgrade TRE's.
It's just a wee bit of a gamble price wise. The regular 2500HD ends are like what, 35$ from Rock Auto?
by HARDTRAILZ » Wed Sep 25, 2013 11:18 am
I do wonder if some decent stock style with the rough country sleeve would be enough though. Simple, but stronger and not a lot of cost to try. I may just order them and see how they do, but buy a back up set just in case. Still be cheaper, but will be a pain if it doesnot work out and the bigger ones still need bought.
by Moots1288 » Wed Sep 25, 2013 11:35 am
by ErikSS » Wed Sep 25, 2013 11:41 am
Does anyone know if Moog uses the same thread between the inners and outreach so the sleeve could be used on them. I was told they would be so that people could replace an inner OR outer. Cause Im thinking Moogs with sleeves would be about $200 total...
by HARDTRAILZ » Wed Sep 25, 2013 11:50 am
A little research has found some claims on H2 forums that the Fabtech outers are Moog outers, just the inner is different.
by Moots1288 » Wed Sep 25, 2013 12:37 pm
by HARDTRAILZ » Wed Sep 25, 2013 2:41 pm
Cognito and Kryptonite are brands showing up with the Hummer guys.
Figure the silvy, H2, duramax forums will be full of experience and reviews.
by mikekey » Wed Sep 25, 2013 4:05 pm
Just buy them Matt!
by Moots1288 » Wed Sep 25, 2013 4:45 pm
by ErikSS » Wed Sep 25, 2013 5:49 pm
The RC sleeves fit over the body of the tie rod end. Any tie rod end with larger than stock TRE body can not use them. I ordered Moog and I currently plan to use nuts as fishticks suggested as there is only a little exposed thread on mine. However... If I can find a way I may build my own sleeves to fit the Moog. I can't justify the cost of these premium TREat.
by mikekey » Wed Sep 25, 2013 6:40 pm
Who needs to justify it. Give in to your irrational desires! You know you want to. :) hehe
