4in+ front suspension lift....alignment..????
by bartonmd » Sat Aug 10, 2013 10:03 pm
DirtyBacon04 wrote:Did anyone else think of this?
That's actually exactly what I was thinking.
by jonbo2002 » Mon Aug 12, 2013 8:01 am
all in all this was almost as entertaining as zombie. maybe we need a smiley for tenny now. I will say I must commend you Bill on not losing your temper there. you must be getting too used to these "asshats" to use your word!
jonbo2002
by Tenny » Mon Aug 12, 2013 12:35 pm
alignment came out almost perfect, caster was still slighty too negative. but good.
the only way to get it perfect would be to elongate the holes in the subframe, and it wasn't
out bad enough for me to do that, she rides perfectly straight down the road now..
I also repositioned my rear shocks from the stock mount, and moved it down 3 inches.
as 4in rear lift was maxing out my rear shocks, and had NO upward movement AT ALL.
drilled a hole in the frame, and welded a nut for the shock bolt.....easypeasy.
thanks for the ones who directed me that it could be done
:fro:
Tenny
by jonbo2002 » Mon Aug 12, 2013 12:50 pm
Glad you got it all set, can you post pics of your shock mount?
jonbo2002
by james02 » Mon Aug 12, 2013 12:52 pm
Excellent... :Iagree: Pics please!
james02
by jonbo2002 » Mon Aug 12, 2013 12:55 pm
oh and nice to see you back too :cheers:
jonbo2002
by fishsticks » Mon Aug 12, 2013 2:52 pm
Tenny wrote:alignment came out almost perfect, caster was still slighty too negative. but good.
:fro:
If you decide you want longer rear shocks, P/Ns for Bilsteins can be found here: viewtopic.php?f=15&t=3438
by ErikSS » Mon Aug 12, 2013 5:03 pm
How much fender height did you gain?
by Tenny » Mon Aug 12, 2013 5:49 pm
jonbo2002 wrote:Glad you got it all set, can you post pics of your shock mount?
yes.....wifery has the truck at work.....when she gets home ill take a few pics
Tenny
by Tenny » Mon Aug 12, 2013 5:56 pm
ErikSS wrote:How much fender height did you gain?
so far....without the tires (285/70/17s)
she sits at
LF....36 3/8"
RF...36 1/4"
LR...37 3/4"
RR..37 3/4"
I just scored a used set of bridgestone dueller revo 2s
that are going on as soon as the spacers and centering caps come.
cant wait...
Tenny
by Tenny » Mon Aug 12, 2013 6:45 pm
before and after
with a 4in spacer lift and flipped UCAs only
Tenny
by Tenny » Mon Aug 12, 2013 6:53 pm
relocated shock
shock relocate 2.jpg (37.9 KiB) Viewed 18098 times
Tenny
by Tenny » Mon Aug 12, 2013 6:55 pm
then I moved it again, I didnot like that location.
shock relocate.jpg (34.86 KiB) Viewed 18097 times
Tenny
by boog2006 » Mon Aug 12, 2013 6:58 pm
Doesn't seem like that's as strong as stock placement. ?
Why not just buy the right shocks?
Are those pink?
Boog2006
Boog2006 Build Thread
boog2006
by fishsticks » Mon Aug 12, 2013 7:08 pm
boog2006 wrote:Are those pink?
I think it's his wife's rig.
Tenny, you may want to lengthen the bump stops with that setup.
by Tenny » Mon Aug 12, 2013 7:52 pm
yea I thought about that, but the rig wont see any heavy wheeling.
(until shes tired of it, and its "officially" mine) but, for now its her daily.
and she said, "I want pink"..hahaha, what do I do..??tell her NO..haha
when I do take it over, a body lift will go in and (at least) 35s with
(at least) 4.10s.
I kinda hopes she gets sick of it quickly hahaha, that 5.3 moves
:fro:
Tenny
by Gordinho80 » Tue Aug 13, 2013 9:03 am
I don't like the location of that mount at all. I wouldn't take it down the highway let alone a trail of any kind.
I'd just shell out the few bucks for a longer shock... or keep the top mount and move the bottom, where you have a little more room to re-position it a couple of inches and still be in the safe zone.
by The Roadie » Tue Aug 13, 2013 10:24 am
The stock design puts the mounting bolt in double shear for a critical reason. Cantilevered like that is risky. I'm sure one of our mechanical engineers will be along soon.
by v7guy » Tue Aug 13, 2013 10:43 am
I would box it in personally, or sleeve the frame and run the bolt clear through the frame and leave it in single shear like it is. I'd be a little worried about that setup, but I don't know what kinda loads a shock is seeing and what the metal of the frame will support. I'm not an engineer though.
Hope the wife likes the ride!
by fishsticks » Tue Aug 13, 2013 11:12 am
I'd have to see the mount in person before passing judgement like my comrades above.
The rear of my crawler has the shocks in single shear on both sides. Never a problem.
What's the thickness of the metal you're into there? I don't have a TB in my driveway to reference.
