Wheel spacers not fitting.
by feets » Wed Jul 31, 2013 10:37 am
Can't get my wheelspacersto fit at the small machined surface approximatly .100 before sitting against the axle flange. Best i can measure is a .014 inteference there. What should i do the get the adapters installed properly?
Can't find any thread with this problem.
Thanks
feets
by ErikSS » Wed Jul 31, 2013 10:41 am
Did you take any pics?
by navigator » Wed Jul 31, 2013 10:41 am
where did you get the spacers?
Is the issue on the front or rear? Did you remove the little clips holding the rotors on?
Is it the hub centric part causing the problems?
Mine came from Mark, they went on the hubs fine but my wheels were a tight fit being wheel centric.
Do you have any rust build up? You don't list your location so we don't know where you are from.
As they say, a pic is worth a 1,000 words.
by The Roadie » Wed Jul 31, 2013 11:17 am
If it's not the clips, then it's the hubcentric lip (a better description would help). Also interested who machined your spacers, and if you contacted the vendor first.
Reason: Better phrasing
by Moots1288 » Wed Jul 31, 2013 12:26 pm
The Roadie wrote:If it's not the clips, then it's the hubcentric lip (a better description would help). Also interested who machined your spacers, and if you contacted the vendor first.
it sounds like the hub centric lip but I could be mistaken.
by feets » Thu Aug 01, 2013 8:19 am
i will just say that, i'm an idiot...lol
I do have the spacers installed, and new kicks tomorrow woo hoo
feets
by djthumper » Thu Aug 01, 2013 9:18 am
feets wrote:i will just say that, i'm an idiot...lol
Do tell... Unless you want people to think oh just another idiot... :facepalm:
by The Roadie » Thu Aug 01, 2013 9:18 am
Please don't be like that. Tell us what really happened and then we'll be able to give better advice to the next one who does it. I guarantee you won't be the last one to do whatever you did.
by JorDaneeKey » Thu Aug 01, 2013 11:58 am
That statement has been said or thought at least once, if not more, by every human being on this forum. Don't let it discourage you! Just learn from it.
JorDaneeKey
by drburke » Thu Aug 01, 2013 12:10 pm
Ironic. Same problem with mine, I just got them from Mark. Although in my case, it appears to be mismatched stud threads.
drburke
by Moots1288 » Fri Aug 02, 2013 3:25 pm
drburke wrote:Ironic. Same problem with mine, I just got them from Mark. Although in my case, it appears to be mismatched stud threads.
how many of them where mix matched?
by drburke » Fri Aug 02, 2013 5:30 pm
All of the studs on the spacers are the wrong threads. Neither the stock lugs or the spacer lugs would work. Apparently this set was a rushed set as the first were lost in transit. Mark and I brainstormed for a few hours before he shipped out new studs yesterday.
drburke
by navigator » Fri Aug 02, 2013 9:28 pm
very odd, you should get 12MM to bolt to the hub and either 12MM or 14MM to bolt to the spacer.
by drburke » Fri Aug 02, 2013 11:42 pm
I thought so as well. I've never heard of this happening (seems to be a common trend in my automotive life-- i am murphy's law in the flesh). The 12mm nuts included work on the hub studs fine, it's the studs on the spacer that are the problem. the lugs only go down about 1/2 inch before they lock up, and if you force them it'll start cross threading.
drburke
by v7guy » Sat Aug 03, 2013 1:32 am
James02 was just telling me this evening he had the same problem with a set of adapters he got the other day. I wonder what's going on?
by Trail X » Sat Aug 03, 2013 8:01 am
I bet they are 1/2" threads, and M12 nuts. The diameters are close enough, but the thread pitch is slightly off.
by james02 » Sat Aug 03, 2013 8:15 am
v7guy wrote:James02 was just telling me this evening he had the same problem with a set of adapters he got the other day. I wonder what's going on?
Yea, fairly deflating.... I planned an all day truck cutting session.... I too had a bit of a mix up with Mark, I bet mine were rushed also.... Not bashing Mark in any way, he shipped the wrong thing and corrected the situation.... Sorta.... :facepalm: :wallbash:
james02
by ErikSS » Sat Aug 03, 2013 11:01 am
JamesDowning wrote:I bet they are 1/2" threads, and M12 nuts. The diameters are close enough, but the thread pitch is slightly off.
I though the same thing as soon as I saw the pic.... But someone beat me too the punchline! lol
by mikekey » Sat Aug 03, 2013 2:36 pm
Ours were M12 with 1/2" threads.
by ErikSS » Sat Aug 03, 2013 2:59 pm
Mine were 14mm threads. Thank god too, cause I ordered my lug nuts from Ebay without checking them. lol
