by drburke » Sun Jul 21, 2013 6:33 pm
JorDaneeKey wrote:Totally misunderstood your post. For some reason I was thinking "bumper" meant you had gotten a custom bumper from Barton. We never even considered touching ours. It has stayed off and will until we get a custom front bumper. As for the rear, I forgot how much of a pain that was. Were it not for my step-dad's acetylene torch, we would've never gotten the bolts loose, I'm sure.
I'm not touching the front either. Picking up Barton's bumper on Tuesday.
v7guy wrote:sway bar delete
Scale of 1-10, how much fun was the front sway bar :poke:
drburke
by fishsticks » Sun Jul 21, 2013 6:53 pm
Dipped the TB.
by RyansTBLS » Sun Jul 21, 2013 6:59 pm
You don't have a tb...do you? :poke:
RyansTBLS
by dvanbramer88 » Sun Jul 21, 2013 7:07 pm
Nice. Best improvement ever IMO. (Talking from experience with Josh's TB)
I bet there was some swearing to go along with those cuts.
by fishsticks » Sun Jul 21, 2013 7:37 pm
RyansTBLS wrote:You don't have a tb...do you? :poke:
I still work on it. :P
by RyansTBLS » Sun Jul 21, 2013 8:23 pm
Oh yea, I forgot you sold it with a lifetime guarantee :slap:
RyansTBLS
by navigator » Mon Jul 22, 2013 8:20 am
On Friday installed Dorman 265-811 Transmission Oil Pan. Based on what I had read this was supposed to be the deep pan so I bought a deep filter as well. Evidently I already had a deep pan/filter because they looked the same except for the drain in the bottom.
It went on without a hitch. Hopefully I'll get the cooler installed this weekend.
by bartonmd » Mon Jul 22, 2013 8:53 am
Just as an aside, since this is a "GMT" thread not a "TB" thread... The Pitman arm on the Chevy trucks might be the biggest PITA job I've ever done on anything. Where do you want the main shaft of the steering box to point, to make it really easy to work on? That's right, 3" away, directly at the front IFS crossmember that's welded in, and right behind the anti-roll bar. You're supposed to remove the steering box from the vehicle to do this job, but that would mean bleeding lines and having to find some place to get like 300ft/lbs on the nut. Got the nut off with a pipe wrench and a 3ft cheater bar, unbolted the box and moved it to a different hole (put the lower mounting ear in the top mounting hole), cut the pitman arm off with a die grinder when my pitman arm puller broke, while pulling on it with a universal disconnect tool, used an impact to get the new arm most of the way on, re-mounted it its home, and put the last turn and a half on it with the same pipe wrench and 3ft cheater bar.
Idler arm mount, idler arm, pitman arm, and steering damper took me 8 hours to do.
The fuel pump I did in the morning took me a little over an hour, because of being able to just jack up the bed and not move the tank.
by v7guy » Mon Jul 22, 2013 9:04 am
Poke? I don't understand?
It's been a long 36 hours, you're gonna need to spell it out for me lol
by dvanbramer88 » Mon Jul 22, 2013 9:18 am
navigator wrote:On Friday installed Dorman 265-811 Transmission Oil Pan. Based on what I had read this was supposed to be the deep pan so I bought a deep filter as well. Evidently I already had a deep pan/filter because they looked the same except for the drain in the bottom.
What we learned on GMT400's is, The shallow pans are "flat" and the deep pans have the "step." In other words, the shallow pan is the same depth over the whole pan, and the deep pan has a shallow end and a deeper end.
The one you posted in definatly a deep pan.
by dvanbramer88 » Mon Jul 22, 2013 9:25 am
bartonmd wrote:Just as an aside, since this is a "GMT" thread not a "TB" thread... The Pitman arm on the Chevy trucks might be the biggest PITA job I've ever done on anything. Where do you want the main shaft of the steering box to point, to make it really easy to work on? That's right, 3" away, directly at the front IFS crossmember that's welded in, and right behind the anti-roll bar. You're supposed to remove the steering box from the vehicle to do this job, but that would mean bleeding lines and having to find some place to get like 300ft/lbs on the nut. Got the nut off with a pipe wrench and a 3ft cheater bar, unbolted the box and moved it to a different hole (put the lower mounting ear in the top mounting hole), cut the pitman arm off with a die grinder when my pitman arm puller broke, while pulling on it with a universal disconnect tool, used an impact to get the new arm most of the way on, re-mounted it its home, and put the last turn and a half on it with the same pipe wrench and 3ft cheater bar.
Tell me about it. I took the steering gear box out to do mine. Three bolts and 2 lines. Wiggled the gear box out with pitman still on it. My weak-ass electric impact wouldn't do squat with the puller. I took it down to my neighbors shop to borrow a real pneumatic impact. A couple burps and it came right off, and same thing to put the new one on. Completely worth the 10 minute trip down to his shop. Saved a lot of ball breaking.
When I did the same job on my truck in the spring, the idler arm and bracket and steering stabilizer went pretty quick compared to the pitman.
But to be fair, I spend 12 hours doing lower ball joints at the end of May. :shoot:
by bartonmd » Mon Jul 22, 2013 9:59 am
I was using an Aircat 1150 that's supposedly good for 1150ft/lbs of torque (at 175psi, where they're all rated. I run on 95-130psi, though). It didn't even pop off at all, until I was almost entirely through the pitman arm with the die grinder, and gave it one last hit on the impact. Holy shit!
by dvanbramer88 » Mon Jul 22, 2013 1:10 pm
I couldn't even tell you what my neighbor's shop has. I know his brother has a boner for spending too much on absolute top of the line Snap On tools. So it wouldn't surprise me if they were running something along those lines pushing 200 PSI. They have a tire machine so their air supply needs to be not only high PSI but high CFM also.
by bartonmd » Mon Jul 22, 2013 2:04 pm
Tire machines only require about 90psi, and volume can come from a big tank, like the 60 gallon one I have.
by james02 » Tue Jul 23, 2013 8:53 am
:pirat:
james02
by v7guy » Tue Jul 23, 2013 10:45 am
james02 wrote: :pirat:
I posted that before the E.R. stitches and concussion... :facepalm:
:mrgreen: :lol:
by DirtyBacon04 » Wed Jul 24, 2013 5:14 pm
Played around with some flex. This is the only way to get this kinda flex within 2 hours of my house...
Installed a new skid plate from MikeyB. Amazing how easily it fits when it's in the right shape...
Also found this lil sparrow guy guarding my truck.
by SaltWaterDrinker » Thu Jul 25, 2013 9:53 am
Squaring Frank's basket away for Saturday!!!
SaltWaterDrinker
by Sugar16 » Fri Jul 26, 2013 9:01 pm
Got my ORTB stickers today. Thanks James :flex dirty:
Sugar16
by Trail X » Fri Jul 26, 2013 9:39 pm
Looks great!
And Chris, that one threw me off too... I didn't realize that ALL TBs had a deep transmission pan from the factory.
