offroadTB.com • View topic - Factory Spring Part Numbers & Associated Lift
by Cable810 » Mon Jun 11, 2012 9:32 am
WHen I installed marks 3" spacer. On the springs I noticed on had a Yellow stripe on the top of the spring and the other white? I couldn't find anything, telling me what they were.... Thoughts?
by Gordinho80 » Mon Jun 11, 2012 9:38 am
What are your RPO codes on the glovebox lid? 6xx and 7xx?
Mario -
by Cable810 » Mon Jun 11, 2012 9:40 am
6da and 7da
by Trail X » Mon Jun 11, 2012 9:53 am
He's got a 2002, I think the RPO codes I have listed are basically for 2004+.
Based on your truck being a 4WD SWB, you can bet that they are both somewhere around 83s.
by Cable810 » Mon Jun 11, 2012 9:56 am
Ok thats the answer I got on GMT a while back. I didn't know that they had the Yellow and white on the springs then.
by anthonyl79 » Tue Oct 02, 2012 4:44 pm
According to my build sheet I have a 82 and an 83. I would like to reaplace them while I am adding my 2.5" lift in. I am running monroe sensa tracks, and not willing to swap them at this time. They have only 12K on them. Would it be okay to run with the 86's in the front? Also what is the purpse of them running 2 different springs in the front? and do I need to do the same? I do want to be able to drive this on the highway and some small easy trails. At this time I do not plan on adding any heavy bumpers or a winch to the front. I have a build sheet that 07TB from the OS ran for me some time ago that I will include incase I missed something.
LIGHT GRAY
28I - LIGHT GRAY 6HP - SUSPENSION
7HN 8NS - SUSPENSION
9NS - SUSPENSION
That is how it was sent to me from my vin number.
anthonyl79
by navigator » Tue Oct 02, 2012 4:47 pm
GM mixing springs is pretty common on our platform, likely due to expected load distribution and handling.
You should be fine switching to the 86s if you can find them.
We don't really have an option except coil overs for longer front shocks so if you are satisfied with your shocks you should be fine.
by The Roadie » Wed Oct 03, 2012 8:58 am
by nickgutnick » Sat Dec 01, 2012 12:38 pm
nickgutnick
by DustinC1989 » Sat Mar 16, 2013 4:20 am
Well research has all come up "computer selected suspension" for 6wz/7wz and there are no tags on the front springs.
Rear springs are light green (88) driver and pink (84) passenger, not that info matters since the rears will be swapped to Z71's. Guess the fronts will be swapped to MOOG 86 equivalents and call it good.
DustinC1989
by v7guy » Sat Mar 16, 2013 4:36 am
You should be happy with the 86 equivalents. Looking forward to hearing about the lift you get. Keep us updated, lots of people are looking for this info
by DustinC1989 » Sat Mar 16, 2013 5:13 am
They will be going on with Marks 3" lift whenever I get to start ordering stuff. Not coming together as fast as I had hoped.
But buying a house kinda kills and budget for toys. Have a lift and goodies, or have down payment and closing cost saved in the bank...
When the time does come, I will be sure to let everyone know how they work out
DustinC1989
by Darkrider_LS » Mon Apr 01, 2013 5:33 pm
Ok wound up finding this thread after seeing it linked over on GMTnation while researching lift options for my truck.
According to my RPOs i have 6NT and 7NT front springs what are these equal to?
Darkrider_LS
by djthumper » Mon Apr 01, 2013 6:02 pm
Without digging too much probably 82 or 83s
by motorhead1117 » Thu Apr 11, 2013 10:52 pm
Mine are 6BG 7SS what are these? Are there RPOs for the rear? I have the ext north face ed. and want the front rear bumpers skids body and susp. lifts any recommendations on spring rates?
motorhead1117
by TBYODA » Mon May 13, 2013 1:29 pm
by Trail X » Mon May 13, 2013 1:31 pm
I'm going to update the first post with the sold-out status of these springs... Is it 89s, 88s, & 87s that are sold out?
by Wahugg » Mon May 13, 2013 1:43 pm
86's are very hard to come by as well
Wahugg
by TBYODA » Mon May 13, 2013 2:18 pm
The 89 come up on gmpartsdirect.com but I am not sure if that means they are in stock or not .
by Wahugg » Mon May 13, 2013 2:19 pm
I thought 89's were still obtainable?
Wahugg
