offroadTB.com • View topic - Lift/Tire Size Chart
by navigator » Thu Apr 18, 2013 10:16 am
Hi Cody, after the original chart I have only added folks that have requested their build get added or had tire sizes different than already listed. I'll add you to the list.
by darring70 » Thu Apr 18, 2013 10:41 am
darring70
by plaen » Thu Apr 18, 2013 3:52 pm
plaen
by boog2006 » Fri Apr 19, 2013 10:41 am
Size Height Width Spacer 2in 4in 6in trim Build Thread/Owner
265/70/17 31.7 10.7 Y Y N N Y
Good Year Duratracs
trim - INNER FENDER LINER FRONT ONLY
boog2006
by darring70 » Sat Apr 27, 2013 9:30 pm
darring70
by Cable810 » Sat Apr 27, 2013 9:47 pm
I had to too.
by navigator » Sun Apr 28, 2013 9:40 am
I had to hit that lower support arm with a hammer a few times but no trimming required.
I'll update the charts to have a ? because some need trimming and others do not.
by v7guy » Mon Apr 29, 2013 12:21 am
by bilit66 » Sun Jul 21, 2013 1:39 am
Just to add to the fit guide. I have 20x8.5 with 15 offset. Tires are 275/55R20. They clear the ball joint with no spacers. Had to do very minor trimming. I do have 2 1/2" suspension and 3" body lift. 32x11
06 Denali XL
MarkMC 2 1/2" Suspension Lift, MarkMC 3" Body Lift
Beilstein HD's in the Front, BDS 55619 Lift Kit Shocks in the Rear, 32x11 No Spacers
bilit66
Vehicle: GMC Envoy XL
by BigBen » Mon Jul 22, 2013 7:34 pm
I have 285/70-17. Spacers. +12 offset. Over 6" total lift. No trimming needed yet.
Sent from my iPhone using Tapatalk 2
BigBen
by jhmeg2 » Tue Oct 15, 2013 12:37 pm
Ok every one, here's the deal. I am going to leave the 3" suspension and 3" body lifts on, but the 35" are off and up for sale. I am puting on NEW fenders, and want to use the tallest tire I can, without having to cut the fenders. Cutting plastic is fine since most of it is already cut or gone. I will need spacers I think, so I am also willing to trade my 35" rimes and tires for a set of H3 rims and whatever the cost of the tires. Or what ever I am trying to say.... if you had questions or a comment, just hit me up.
:flex dirty:
jhmeg2
by TBYODA » Tue Oct 15, 2013 3:13 pm
by hayes » Fri Oct 18, 2013 7:37 pm
I looked at the chart, and I'd like to ask a question: Can I get 265/65r17 to fit on a stock 06 TB LT? I'd like to step up in size but I am not ready for a lift. Having read the chart, it says N for 2,4,6,8 in lift. There is no one to confirm (by name on the right side of the chart) that they will fit. Can someone give me a little clarification, as I might just be misunderstanding the chart?
hayes
by TBYODA » Fri Oct 18, 2013 8:41 pm
by navigator » Fri Oct 18, 2013 10:15 pm
you won't need a lift but depending on your actual tire size you could need wheel spacers.
You are likely fine unless the tires you pick run big.
by hayes » Sat Oct 19, 2013 10:40 am
hayes
by sarg » Thu Mar 20, 2014 5:25 pm
to add to this 265/60/18 on factory Denali wheels barely squeaks by. Might grind a bit to make me feel better. Stock everything at this point til my MarkMC lift goes on this weekend along with Z71 springs. It has about 1/4 of an inch space actually, but hard to tell from the angle of the shot. Cooper Discover AT3's.
sarg
by The Roadie » Thu Mar 20, 2014 6:20 pm
Hi, Mike! Thanks for joining, and adding to the data base. Saw this pic on GMTN.
by sarg » Thu Mar 20, 2014 6:35 pm
Thanks Roadie and thanks for all the advise in so many threads. It has been helpful in planning the future of the truck.
sarg
by DustinC1989 » Thu Mar 20, 2014 10:32 pm
I've been running 265/60-18 Hankook Dynapro AT's for awhile now, have about the same clearance.
Very curious to see how they look after the lift, be sure to post pics
DustinC1989
