ORTB Trail Experience Rank - Your Change Requests Go Here!
Document your truck's build, start to finish.
One thread per member is allowed.
NO DISCUSSION is allowed in the build threads, comments from users other than the thread author will be deleted. Please place links to specific modification threads. All comments can go here: viewtopic.php?f=25&t=2041
Please keep the first post updated with a list of your modifications.
The first post should follow the guideline and layout listed on this thread: viewtopic.php?f=25&t=79
Thanks - The ORTB Team
by fishsticks » Mon Mar 25, 2013 12:47 am
I guess I'm kind of extreme... or something.
Random threads...
viewtopic.php?f=55&t=2506
viewtopic.php?f=55&t=2358
viewtopic.php?f=55&t=2127
by Trail X » Mon Mar 25, 2013 8:41 am
You no longer count.
by navigator » Mon Mar 25, 2013 8:48 am
LOL
by fishsticks » Mon Mar 25, 2013 11:50 am
JamesDowning wrote:You no longer count.
I half expected to be reclassified as "Traitor."
by dvanbramer88 » Mon Mar 25, 2013 12:20 pm
Is "made in japan" a trail rank? That would be suitable for Donny...
by navigator » Mon Mar 25, 2013 1:07 pm
he still has the TB and doesn't have the 4Runner functional yet, give him two more weeks then you can really give him grief.
by Cable810 » Tue Mar 26, 2013 7:36 am
dvanbramer88 wrote:Is "made in japan" a trail rank? That would be suitable for Donny...
Agreed :D
by boog2006 » Thu Apr 18, 2013 10:22 pm
Offroad Rated: Lifted truck and posted proof of at least 3 off highway trips, one of which should be considered non-stock passable.
http://forums.offroadtb.com/viewtopic.php?f=56&t=4274
http://forums.offroadtb.com/viewtopic.php?f=56&t=4263
http://forums.offroadtb.com/viewtopic.php?f=56&t=3487
Boog2006 Build Thread
boog2006
by Trail X » Thu Apr 18, 2013 10:27 pm
Updated, with pleasure.
by Regulator1175 » Thu Apr 18, 2013 10:57 pm
I text Wink and told him to check this out, he definitely is out of place in the mall crawler build. I can vouch for at least 3 Badland trips that he has done with the midwest crew.
by dvanbramer88 » Fri Apr 19, 2013 12:19 am
Moots1288 should get bumped from mall rated to trail ready. He did make TECORE 7 and my thanksgiving trip.
by Trail X » Fri Apr 19, 2013 9:47 am
Its their duty to get their ranks changed.
Also - I have updated the request procedure. Please now also include a link to your build thread in your request.
by Kuchar09 » Fri Apr 19, 2013 10:47 am
Trail Ready?
Can I use another members trip report that I am in?
http://forums.offroadtb.com/viewtopic.php?f=57&t=3483
http://forums.offroadtb.com/viewtopic.php?f=74&t=2389
Working my way up in the world whoop whoop!! lol
Kuchar09
by dvanbramer88 » Fri Apr 19, 2013 11:02 am
I guess I qualify for Trail Ready. I've only technically guided 1 trip.
viewtopic.php?f=57&t=4262
viewtopic.php?f=57&t=3827
viewtopic.php?f=57&t=3376
Build thread: viewtopic.php?f=74&t=2396
by Trail X » Fri Apr 19, 2013 11:39 am
Kuchar09 wrote:Can I use another members trip report that I am in?l
Thanks Travis, and yes, as long as you were there, and the report was posted, you're good. That's why it's good to start a trip report with a list of who attended, if there were others.
dvanbramer88 wrote:I guess I qualify for Trail Ready. I've only technically guided 1 trip.
You're a bit of an anomaly. You don't have a lift, right?
by dvanbramer88 » Fri Apr 19, 2013 11:45 am
Correct. No lift, but I have guided a trip and have plenty of passive, dynamic, and static recovery experience.
So I'm kinda in a grey area between ranks.
by navigator » Fri Apr 19, 2013 11:46 am
does turning up your torsion bars count?
I know a lot of the Z71 crowd can turn up their torsion bars and run 33's and we have to have 4 inches of lift, cut and re-gear just to get to 33s.
by dvanbramer88 » Fri Apr 19, 2013 11:56 am
I can stuff 285's with a little trimming. They're 32.6 or something like that. I'm actually going to look at a set tomorrow.
I don't really want to crank my T-bars. But you're right, I don't need much at all to run a real 33.
by HARDTRAILZ » Fri Apr 19, 2013 1:22 pm
navigator wrote:does turning up your torsion bars count?
Z71 is just decals, plastic skids, n shocks. No real difference. They also need to re*gear as much as we do since most start w 50-100 less HP even though a 33 is not as big a jump in tire size for them.
I turned the bars on several trucks. Ride goes to hell pretty quick n you need aligned. Better off w a body lift to clear tires.
by dvanbramer88 » Fri Apr 19, 2013 3:36 pm
Rory runs 285/75/R16 with 3.73's and a trans cooler.
I will be running the same set-up.
And if you look over at the full size forums, tons of guys run 285/75 on these trucks no problem.
I mean 4.11 gears would still be nice, but not necessary.
Return to Build Threads
