by JorDaneeKey » Sat Mar 30, 2013 11:57 am
After 4 junk yards we finally found a couple Trailblazers 2 cities over. Got a new fender for $48 bucks. Would'be been $40 if we had taken the smashed one in, but I didn't want it taken off until a new one went on. Looks like trail damage after all. ;)
JorDaneeKey
by Blazintrails03 » Sat Mar 30, 2013 5:08 pm
Finally pulled my running boards off today
Blazintrails03
by DustinC1989 » Sat Mar 30, 2013 6:28 pm
Fixed the stupid sagging rear door seals and washed what will hopefully be the last of the salt off
DustinC1989
by navigator » Sat Mar 30, 2013 9:02 pm
swapped out spacers for adapters and installed some Tahoe wheels.
I'll get pics once I get my new tires installed
by Regulator1175 » Sun Mar 31, 2013 12:40 am
Blazintrails03 wrote:Finally pulled my running boards off today
I got all the hardware to put mine back on.
by KE7WOX » Sun Mar 31, 2013 2:18 am
DustinC1989 wrote:Fixed the stupid sagging rear door seals and washed what will hopefully be the last of the salt off
Did you just glue them back or did you do something else? I need to do that (or maybe just change them, since they smell like stale balloons)
KE7WOX
by DustinC1989 » Sun Mar 31, 2013 3:06 am
3M Super trim adhesive, clamped them for about 2 hours. I don't think they are going anyplace now
DustinC1989
by darring70 » Mon Apr 01, 2013 2:32 am
At the shop installing my new front and rear suspensions:
Issues: One of the screws from the front strut mount broke, I have to wait until Monday to buy the part
Shocks Skyjacker N8030 bushing (button) does not fit the bracket I had to remove the bushing from the old shock and adapt it to the new one.
Here is some pictures
Suspension 3.jpg (12.16 KiB) Viewed 21437 times
Suspension 2.jpg (12.5 KiB) Viewed 21437 times
Suspension 1.jpg (12.74 KiB) Viewed 21437 times
darring70
by navigator » Mon Apr 01, 2013 6:31 am
darring70 wrote:....Shocks Skyjacker N8030 bushing (button) does not fit the bracket I had to remove the bushing from the old shock and adapt it to the new one.s
This is a pretty well documented "feature". It is one reason so many folks went with the BDS shocks at first. Most of us running the SkyJackers(and others) just put several washers on either side of the bushings to take up the slack. You should like those shocks though, they ride good.
by darring70 » Mon Apr 01, 2013 7:15 am
Actually the problem was not add some washers, the pronlem was that the hole of the bushing was to wide for the bolt, but it is fixed
Thanks
darring70
by djthumper » Mon Apr 01, 2013 9:49 am
What do you mean too wide for the bolt?
by darring70 » Mon Apr 01, 2013 10:00 am
I do not know how to explain it but the button part of the shock has a bushing and like a metal tube inside the bushing, that metal piece is to big so when the bolt that holds the shock goes through the shock is still lose
darring70
by djthumper » Mon Apr 01, 2013 4:15 pm
ah but the washer would hold it firm or get a half inch bolt...
by darring70 » Mon Apr 01, 2013 5:15 pm
Rear suspension installed
darring70
by darring70 » Mon Apr 01, 2013 5:17 pm
Front suspension installed
Overall
darring70
by dvanbramer88 » Mon Apr 01, 2013 5:19 pm
Looks good! Now all you need is those tires and skids and you're ready for TECORE!
by Trail X » Mon Apr 01, 2013 5:27 pm
HARDTRAILZ wrote:I carry spare silver ones rated higher than black ones hanging on my bumpers. Color doesn't matter...
I know the finish doesn't necessarily change the load rating, but of the ones I've seen, the chrome finished ones were not stamped or rated for load. They were some sort of bling item for lifted show poodle H2s or something.
I hadn't seen a chrome one that was even stamped with a rating. Not saying they don't exist, just hadn't seen any. For some reason it just raised a flag in my mind - wanted to make sure they were rated.
by darring70 » Mon Apr 01, 2013 5:29 pm
Rides great, better than my 2007 tahoe
darring70
by djthumper » Mon Apr 01, 2013 5:33 pm
darring70 wrote:Rides great, better than my 2007 tahoe
Of course it will when you borrow the springs from the Tahoe...
by tbangert » Mon Apr 01, 2013 7:09 pm
Fought with power tools for awhile (need to get my air compressor back and buy some air tools) but got my Zone 2" body lift installed. I must say it is a nice kit, but their directions are horrible!!! Very poorly written.
Now for some new meats and some steel!
tbangert
