offroadTB.com • View topic - 16s or 17s
16s or 17s
by rz03LTZ » Sat Mar 23, 2013 2:31 pm
Which is better for off road?
Does the extra inch of rubber make a difference on a tire with a 16 rim but the same overall diameter?
rz03LTZ
by dvanbramer88 » Sat Mar 23, 2013 2:37 pm
Most would say go for the 16. Especially if you will be airing down.
And with all the chevy and ford trucks that use 16 inch rims, finding a tire in an emergency will be easier with 16 inch rims.
by DirtyBacon04 » Sat Mar 23, 2013 3:14 pm
:Iagree: :Iagree:
:safe:
by Diacom » Sat Mar 23, 2013 3:37 pm
I don't agree....
Reason being is once you go past a certain ratio of tire sidewall/rim height, it wont make any difference really on which of the two you pick.
For most however, being tire size restricted, yes 16" will give you more sidewall to play with typically.
Also, as an employee at a GM dealership, 16" is going by the way side if the new models are any indicator. Lots of 17 and 17+....
Edit...
On another note, the advantage of the larger wheel, is while aired down once you pass the similar sidewall/rim height, you gain from the larger wheel in ground clearance per say. So the balance is at what point is it moot, say 20" wheels if you can't run enough tire to be bennificial.
by Opeth » Sat Mar 23, 2013 3:40 pm
17's look better, and air down just fine. I run 265/70r17... Stock size Chevy pick up tire, very available. Most of use carry full size spares and tire repair kits, at this juncture I'd say go with what's in your budget.
by mikekey » Sat Mar 23, 2013 5:43 pm
Don't ever plan on upgrading your brakes with 16inch rims.
by v7guy » Sun Mar 24, 2013 7:52 am
What Mike mentioned was my first thought. 17s mean you can upgrade brakes if you're inclined. If you don't have wheels in the budget, use what ya got, neither is necessarily bad.
by HARDTRAILZ » Sun Mar 24, 2013 9:32 pm
17s are more common now and allows for brake upgrades...seems like a no-brainer if you are buying wheels.
by fishsticks » Mon Mar 25, 2013 12:39 am
+1 for 17s. The bigger brakes make a difference when you're stopping big tires.
by DustinC1989 » Mon Mar 25, 2013 1:26 am
Another +1 for 17's. Room for bigger brakes, still a good amount of rubber and easy to get tires for.
I hate my factory 18's
DustinC1989
by The Roadie » Mon Mar 25, 2013 11:28 am
by navigator » Mon Mar 25, 2013 11:37 am
I had been browsing CL for full sized rims and decided it wouldn't make a huge difference to me, I would just get what was the best deal. I needed 2 sets so I could match my trailer and TB. It seems easier to find the 16 inch takeoffs right now in my area.
One other thought is tire selection, I noticed that most 16 inch tires have an equivalent in the 17 inch size as well. One missing in the 16 inch area is a 255/75/17 (32X10.00) which several guys on here run. Some folks like that because they get a 32 inch tire with decent width but not the road resistance of a (32X10.50). It seems to be a good balance of capability vs daily driver.
by HARDTRAILZ » Mon Mar 25, 2013 11:53 am
255 75 17 is an oddball that came about with the Jeep Rubicon.
by JCrayton99 » Mon Mar 25, 2013 6:43 pm
I like my 16. I will try to keep them because my next tire is going to be a 255-85-16. I have also done the EXT break mod. 4" of backspacing or less is a must if you want to keep the 16s. Id love to run 255-80-17, If someone made them.
JCrayton99
Rank: Offroad Guide
by TBYODA » Mon May 20, 2013 2:02 am
by v7guy » Mon May 20, 2013 3:16 am
basically the minimum sidewall you want to shoot for is 2x the diameter of the wheel ( it's the figure I read the most often anyways). When you air down you want to keep from smacking the wheel. More sidewall helps. We've gotten to the point that 32" tires are pretty much the starter size tire for our trucks and it's still considered a small tire in the off-road world. Bigger tires are in general more capable in many off-road situations. But as you commented there are on road sacrifices to be made.
by TBYODA » Mon May 20, 2013 6:35 am
by fishsticks » Mon May 20, 2013 12:12 pm
I know the sidewall thing is a general "rule" around here, but after doing the EXT brake upgrade, I wouldn't even consider 16" wheels. The brake upgrade is ridiculously cheap and makes a big difference. IMO, it should be considered for addition to the list of "requirements" for offroading as a safety concern.
1/2" of sidewall isn't going to make a difference. Most people here don't air down past 20psi anyway, so usable sidewall is still there.
by NC_IslandRunner » Mon May 20, 2013 1:06 pm
by Diacom » Mon May 20, 2013 9:01 pm
265/70/17 w/BFG AT's aired down to 15psi will get you some rock rash on your wheels, but then if your worried about a little rash on your wheels, you must be a mall crawler....
