v7guy wrote:Here it is all finished up, I didn't get a picture while it was clean but I suppose it is what it is. I went ahead and drilled a couple small holes in the bumper to drain the water and it seems to do the job pretty alright. The ride is worlds better with all the weight up there. Even managed to get the winch wired up. Not too bad for some cobbled together piece of shit if I do say so myself. I even had a fella ask me where I bought it the other day lol
I cut off the flange on my radiator skid tonight so hopefully all the skids will be back on in a few days.
bartonmd wrote:v7guy wrote:Here it is all finished up, I didn't get a picture while it was clean but I suppose it is what it is. I went ahead and drilled a couple small holes in the bumper to drain the water and it seems to do the job pretty alright. The ride is worlds better with all the weight up there. Even managed to get the winch wired up. Not too bad for some cobbled together piece of shit if I do say so myself. I even had a fella ask me where I bought it the other day lol
Looks good, but WOW, you N-E-E-D to move those shackle mounts!!! The fairlead is OK on that unsupported piece, because its forces are side to side and up and down. The shackle mounts, on the other hand, are pulling in the ONE direction in which that piece has ZERO strength! Hack them off of there and weld them on the under-angled part, right below the winch plate level, right in front of the frame rails (or as close as you can get to there, while still being on the part that faces forward and down).
Moots1288 wrote:^ you said jerked on :happyface:
drwfaulk wrote:Moots1288 wrote:^ you said jerked on :happyface:
damn, beat me to it!!!!!
Moots1288 wrote:drwfaulk wrote:Moots1288 wrote:^ you said jerked on :happyface:
:highfive:
v7guy wrote:So you're saying they could get enough load to buckle the winch plate upward, bend the ribs on the underside of the winch plate, twist those triangle gussets, and then bend over the fairlead mount? Seriously?
What you show above is exactly how it's laid out (excluding the gusset inside). When I put em there I figured I wouldn't see any more loading than the winch would place on it and that the reinforcement ribs on the underside of the winch plate would be enough to keep em from moving around... they are about 4 inches away from those ribs, but still.
I had originally planned to put a couple pieces in just like you show with the thought that it would help reinforce the underside of the bumper since that is probably whats going to get smacked by something when I'm going up and down stuff (and losing oil pressure lol). I figured it would transmit the load from the bottom area that was impacted up to the winch plate. In the end I decided to leave em out in my rush to get it on for the thanksgiving run. It still sits in the back of my mind that I should have put em in. I can definitely see how that inside gusset would strengthen it up for the shackle mount and the bottom of the bumper.
I'll pull it off sometime in the next few weeks and put em in, can't hurt.
v7guy wrote:That's going to piss me off trying to clean and weld up in there, it'd be even worse trying to fix it though. lol
Dave, 6000lbs at 10 miles per hour is around 22k lbft of pull with a recovery strap. That's getting a little scary as far as frame loads go, and 10mph is a pretty stout tug. Generally speaking our trucks are closer to 5000 lbs aren't they? In that case we'd be looking at 18k lbft with a recovery strap given the same scenario. That's a good little bit of pull.
