by Lauron » Wed Sep 26, 2012 12:04 am
Roadie, I followed your comments about the suspension and negative camber but this is not what I have experienced. If you look at JamesDowning's pics showing the UCA stock and reversed you can see the ball joint is farther out. So with out pushing out the LCA, there has to be positive camber.
Right from Fishsticks first experiment to try this, he had positive camber. So it seems to be consistent and makes sense to me. Maybe mine was more pronounced but saying this I am living with it right now. But I am obviously very concious of the bump steer I am getting.
Attached is the current pic. Hard to tell that anything has changed. What was really revealing to me was the change in toe in when I flexed the suspension.
The bds drawing and discussion may help. The principle is the UCA, LCA and Tierod must line up at the instant center with the outer and inner pivot points also lined up to avoid bump steer. With unequal length arms, I believe zero bump steer only happens at one position over some range of travel, not full suspension travel.
So, if the LCA is moved out, the inner tie rod end needs to move out as well. Of course the outers are not moved from their alignment.
As far as selecting an outer tie rod, I do not want to go with an unsealed heim. Inside I hope to have the heim and clevis fit inside the existing rack boot.
Fishsticks, thanks for the warning on the welded ends. I can get the DOM threaded and cut a few wrench slots.
Always a good idea to build in a weak link that is cheaper to replace than the expensive pieces, the rack or pinion. The rack seems pretty stout so what has broken?
I will identify 16 mm TREs that are closest and go to my neighbourhood parts store and ask to measure them. Will advise what I find.
Thanks,
Ron
- Attachments
- Tie rod w.JPG (32.11 KiB) Viewed 143264 times
- bsdrawing.jpg (32.33 KiB) Viewed 143264 times
Build:
