The doc says it takes three months for the tendon to heal and roughly four months until I can work. I'm roughly 2 months in. At the end of the week I go back to the doc to see if I can ditch this orthopedic boot and work on walking and wearing a normal boot. I've welded a little bit, but the orthopedic boot is open toed and even though I wrap it up I'm nervous about dropping some molten metal on my toes covered with a sock.
Jeff, I had the same experiences as Mike. If you spend some money for some better cutoff wheels you'll get further faster. You just got to let the disk do most of the cutting. If you start getting real heavy handed you'll dust/break any disk. Light-ish pressure seems to be key.
For support of the winch base plate I used suggestions from Mike. Metal structures get their support from bends, ridges and curves. So accordingly I welded on a lip on the back of the plate and the front (the fairlead mount). On the bottom of the plate I welded on some ribs to stiffen the winch mount plate up. I posted some pictures above of how I stiffened it.
My biggest concern while welding on this is to not warp the shit out of it. That seems to be what I fight more than anything.
While laying on the couch for the past couple months it occurred to me that it would be easy to mix up the different plates. I figured I would number the mock up piece and then label each plate as I cut it out. Then I took pictures of it so I would know where they went. I've got to finish up welding the braces on the bottom and then I'm going to put it back on the truck so i can start tacking the pieces on.
Most of the work I've done since my last post has been in the last few days. I'll keep working on it, but I don't want to make the healing take any longer than necessary cause i really need to get back to work. This injury has made a noticeable dent in the ole savings. When I can wear some jeans and my boots again, work will progress at a more rapid pace. Apologies for the slow build. I have every intention of having it finished before I go back to work.
