89s 88s 85s oh my! Possible trade!
by fishsticks » Wed Aug 01, 2012 3:56 pm
Got a set of 89s you're worried may be too stiff?
I'm going to convert my front lift to spring only, and I'd like to try some 89s. My 88s are "broken in" but do not sag. I don't think anyone has had issue with 88s topping out, so if you're lighter in the front (no winch, armor etc) this may be your answer. 88s are long gone from the factory.
I need to pull the 88s out from under the truck, and I'd rather not swap in my stocker 85s just to have to pull them back out in a week or two. So if you have an uninstalled set of 89s, all the better. I can get them swapped in a couple hours, so I can turn them around quickly. I would gladly provide a deposit if you don't trust me. :)
Note that I do not want to buy your 89s outright. I already have WAY too many parts hanging around my garage. I'm trying to help out someone who may be having second thoughts about buying 89s. If I need to spend money on springs, I will buy custom wound set at a much stiffer rate than 89s.
I had to send my plasma cutter in for replacement, but my new one will be here tomorrow, so I will be cutting my new upper mounts this weekend. Basically I'm ready to get on this.
I also have a set of 85s for sale. Make offer.
by Jblazin82 » Thu Aug 02, 2012 7:50 pm
I have a set of 89s Ill trade you. Emailed you last night and there off the truck
Jblazin82
by fishsticks » Sat Aug 04, 2012 2:44 pm
Jblazin82 wrote:I have a set of 89s Ill trade you. Emailed you last night and there off the truck
Doh! I'm a doof. PM incoming.
by fishsticks » Sun Aug 05, 2012 2:25 pm
Trade deal pending.
by Jblazin82 » Mon Aug 06, 2012 11:35 pm
Parts sent this morning. Hopefully you will have then Wednesday and I get mine by Monday
Jblazin82
