The Roadie wrote: and a bit less of the "my check engine light has been on for six months now, what should I do?!?!?" whininess.
The Roadie wrote:No, but it means we gotta make sure your junk gets fixed.
JamesDowning wrote:My thermostat code keeps coming back. I'm normally running at about 180*. I just don't have the time to replace it. I even brought it to a mechanic... he turned me DOWN!... he was like "I don't want to get that deep into your engine."... Yeah, thanks for the help you lazy ass.
bobbyblaze wrote:JamesDowning wrote:My thermostat code keeps coming back. I'm normally running at about 180*. I just don't have the time to replace it. I even brought it to a mechanic... he turned me DOWN!... he was like "I don't want to get that deep into your engine."... Yeah, thanks for the help you lazy ass.
Your thermostat runs at 180 ? Mine sits a hair above 210 but I have an OBD2 code scanner that shows live feed while running including the coolant temp. When my dash sensor reads 210+ my scanner is usually around 185*. I believe my scanner.
I'm bringing the scanner to tecore. You can check it against your gagues if you want.
teebes wrote:The Roadie wrote: and a bit less of the "my check engine light has been on for six months now, what should I do?!?!?" whininess.
Uhhm, wait. Does that mean I have to leave now![]()
