Rear shock bushing issue
by AceOfSprings » Sun Jul 29, 2012 10:43 pm
So I was trying to install the bushings in my new bds5500 shocks. All I have are simple hand tools, so I put the screw through it and tried to ratchet the bushing into place. Got the bushing in, now I was able to loosen the nut a little bit and then it got stuck. Not sure if I melted the nut to the screw with friction or what, but it just will not budge. So I am sitting with a shock and bushing with screw and nut on it...not connected to my vehicle. Any ideas on how to get it off?
I have sockets, screwdrivers, and wrenches, that is about it.
AceOfSprings
by chevycrew » Sun Jul 29, 2012 11:48 pm
Sounds like the threads galled, might have to use bigger tools until it comes loose or breaks. Anti-seize will help prevent this from happening again, and PB blaster may help loosen it, but not likely.
by AceOfSprings » Mon Jul 30, 2012 12:16 am
Guess i will just have to find a cutter.
Sent from my mind
AceOfSprings
by Mudwheelin » Mon Jul 30, 2012 1:45 am
Cover up the bushings with something and heat the metal up a bit.
Build Thread:
viewtopic.php?f=25&t=2349
Mudwheelin
by v7guy » Mon Jul 30, 2012 4:15 am
I would imagine any kind of real heat will destroy those bushings.
I would be trying larger wrenches. Maybe a couple breaker bars. Put the socket on one side and stand on the ratchet/breaker bar. Then link a couple wrenches together/put a bar on a ratchet to extend its length or use another breaker bar to loosen the other side.
Could also try cutting the nut or splitting it with a large chisel... just don't smack the shock if you use a chisel.
by tbangert » Mon Jul 30, 2012 6:30 am
I'm not sure if autozone rents them, but a nut splitter would be perfect for that. It would eliminate the chance of //// up that bushing with heat.
tbangert
by The Roadie » Mon Jul 30, 2012 10:22 am
Nut splitter or just hacksaw the bolt next to the nut. You never want to use a bolt in that condition over, especially one that has to absorb the energy of a down-travelling axle and tire when unweighted.
If I didn't have a vise handy, I've gotten bushings in by using silicone spray/grease as a lube, and just hammer it in using a socket as a backing.
by mikekey » Mon Jul 30, 2012 11:25 am
The Roadie wrote:If I didn't have a vise handy, I've gotten bushings in by using silicone spray/grease as a lube, and just hammer it in using a socket as a backing.
Those BDS bushing's where a pain. I couldn't figure out what BDS didn't just pre-install them. But what The Roadie said is pretty much what we ended up doing. I put some white grease on there (tiny amount) and smacked them in with a rubber mallet. Took a few wacks, but eventually went in.
by Trail X » Mon Jul 30, 2012 12:30 pm
Your picture isn't working David.
Have access to any impact tools?
by AceOfSprings » Mon Jul 30, 2012 12:53 pm
no impact tools. I think I will just go get a hacksaw, grease, and a c-clamp. Hopefully that will do the trick. Have to wait for wife to get off work though as she has the only put-together car at the moment. Just going to replace springs for now I suppose. Will re-do the shocks tomorrow.
AceOfSprings
by AceOfSprings » Mon Jul 30, 2012 1:58 pm
Bah, just one problem after another. Just had an Evercraft "3 ton" jack stand buckle. Luckily I was not under the car because it dropped to the ground. Looks like nothing broke besides stand, but anyway im just need a break. Thanks fot all the help and advice though.
Sent from my mind
AceOfSprings
by Trail X » Mon Jul 30, 2012 2:42 pm
Wow David. Glad you weren't under the vehicle. Might want to contact the MFG, they will probably gladly replace it, since it was being used within standard operation conditions.
by navigator » Mon Jul 30, 2012 3:02 pm
glad you're ok David.
I usually have a jackstand under the vehicle if I leave it on the jack.
When I set it on jackstands I always stick the wheels under the frame in case it falls for that reason.
Rims are cheap compared to body parts :-)
by AceOfSprings » Mon Jul 30, 2012 3:26 pm
Yea, think i need to rethink my setup. Dont have any interest in a replacement, i am definately go to a different mfg. I like the wheel idea, will start doing that.
Sent from my mind
AceOfSprings
by AceOfSprings » Mon Jul 30, 2012 11:19 pm
Sent from my mind
AceOfSprings
by mikekey » Tue Jul 31, 2012 7:49 am
navigator wrote:glad you're ok David.
Man glad you weren't under it.! I would contact the manufacturer. You'd be surprised, they might fully replace it or send you an upgrade.
I'm not the only paranoid one then, I stick my tires under the vehicle and usually leave my jack under there as well. My red neck method used to be a big ol' tree log. Being crushed by my car is not a way I want to exit this world. Especially since I think it probably wouldn't be a sudden of enough death.
by Trail X » Tue Jul 31, 2012 12:43 pm
AceOfSprings wrote:
Sent from my mind
Were you by chance on a slope? Looks like the stand was maybe unevenly loaded?
by AceOfSprings » Tue Jul 31, 2012 2:15 pm
no it was flat ground. I was wrenching pretty hard though so there was a bit of forward pressure, that is what did it in.
AceOfSprings
by v7guy » Wed Aug 01, 2012 3:23 pm
Scary as shit man. I've always been paranoid about that and I always leave the jack under the vehicle. Apparently I have good reason to be worried. Really glad you're ok man
by AceOfSprings » Thu Aug 02, 2012 1:14 am
Okay, so I can finally get back to my lift now. Hacksaw made short work of my initial issue. I appreciate all the support here, being new to mechanical work is definately a learning experience.
Sent from my mind
AceOfSprings
