Taking off the old
BDS top plate
Icon top. Female 3/16"X16 holes. Not having male studs makes it tougher to install. Different bolt circle diameter means you need a template to drill your upper coilover bucket.
Start of the template
Had to chase out the threads - Icon was assuming you'd use bolts that didn't go all the way through their plate, but I was.
Template
Drilled
Passenger side installed!
Top
Full length
Bolt heads
Driver's side drilled
Bolted
Installed at the top. Lower yoke mount coming. With the Heim up top, the strut can be moved around easily to put the yoke on last.
Went for a short drive in the dark. After 75K on my HD Bilsteins, these 2.5" Icon shocks are a DREAM. 3/4"-1" less sag under the weight of the bumper and winch and HiLift (180-200 extra pounds) due to stiffer springs. More dynamic testing tomorrow offroad!
