What I'm doing is installing a 44 gal fuel tank from an old Suburban. It measures 33" wide x 26 3/4" long x 13" high. I'll be installing it where my spare tire was and I'll be getting rid of my stock fuel tank because of some "other" mods I'm working on. I'll show and tell later on those.
Here's my progress so far:
First I removed the spare tire "crossmembers"
[Thumbnail]
[/Thumbnail]I still need to remove both of these spare tire "braces"
[Thumbnail]
[/Thumbnail]I'm not sure about the short wheel base versions but my EXT has this "secret" compartment that I'll be cutting out and then welding a plate sheet in it's place. That way I can tuck my new fuel tank tight up inside my frame for some nice ground clearance.
[thumbnail]
[/thumbnail]I'll need to find a way to tuck these rear ac lines out of the way. ( any suggestions on this is welcome)
[thumbnail]
[/thumbnail]Here's my fuel tank I'll be putting in. I'm going to cut the filler neck and weld it facing the direction of the arrow. I'm also going to cut the lip at the seam and then weld the two halves together so the tank can fit better between the frame.
[thumbnail]
[/thumbnail]While I was cutting I decided to flip my trailer hitch upside down. There is much more rear ground cleance. I cut off the steel step support for the bumper and had to cut out the center step of my plastic bumper.
[thumbnail]
[/thumbnail][thumbnail]
[/thumbnail]As you can see is this next pic the bolt holes don't line up. So all I did was pull my trailer hitch out to the next bolt hole to line up. For the time being I'll leave it like this because when I make my steel bumper I'll flip the brackets back so all 6 bolts line up.
[thumbnail]
[/thumbnail]This has been a slow process because of the weather, I live in Seattle area. Any advice on the ac tubes is appreciated. Also, any advice for all the sensors and junk we have monted ontop of our tanks; as you can see my new tank only has a mount for sending unit, but we have about 4 or 5 other things I'll need to mount. I was just going to drill holes in my tank to mount them. Is that all I can do or can I just toss them? lol Thanks for lookin
