offroadTB.com • View topic - MDB Quick-Disconnect Swaybar Links...
Moderator: bartonmd
by cbbryan » Fri Jan 13, 2012 7:02 pm
Whats the status of these? Two of the factory ones are broken on my TB. I would like a set if they are ready or if you need any further testing.
cbbryan
by bartonmd » Fri Jan 13, 2012 7:22 pm
I haven't touched them lately, to be honest... The ones out there are still out there, gathering data...
If you don't need it like tomorrow, I can hook you up...
Our conversation with other guy got me thinking, and I may try and set of female heims with some 1/2-20 all-thread in the middle, to see how they work out...
Shoot me a PM if you're interested...
Thanks,
by HARDTRAILZ » Sat Jan 14, 2012 4:17 am
Consider it sent. The ghetto bolt on---not quick connects I got from Cali are clunking again. Call me and tell what heims to order...
by MD_trailblazer » Sat Feb 18, 2012 3:44 am
Are these ready for ordering as I'm in the process of looking for qd's for my trailblazer
If so are they available for both front and rear
Thanks please let me know
Also is there anyone here in the Maryland area?
MD_trailblazer
by Nakashige » Sat Feb 18, 2012 4:05 am
JD is....
Nakashige
Vendor
by bartonmd » Sat Feb 18, 2012 9:03 am
They're not really in the ordering process just yet, and while they aren't much different, I just haven't done any rears, yet.
by Skidder » Thu Jul 19, 2012 9:58 pm
Mike,
Any updates on this topic?
Skidder
by bartonmd » Thu Jul 19, 2012 10:05 pm
I haven't touched them, to be honest... Several of us are running them and they seem to hold up fine.
When I get a free minute, I'm going to post how to make them, yourself, without a welder. Just takes some female heims, some all-thread, some bolts, some lug nuts, some pins, a cutoff wheel, a drill, and something to hold the bolt while you drill it.
by snowmirage » Thu Jul 19, 2012 10:47 pm
That would be great mike, more or less the perfect project for me.
snowmirage
by bartonmd » Fri Jul 20, 2012 9:15 am
This is copied from an email where I told someone how to make them, some time ago:
MCMaster Carr:
(4) 4444T231 (Steel Ball Joint Rod End with Grease Fitting 1/2"-20 RH Fem Shank, 1/2" Ball ID, 1-1/16" L Thrd)
(1) 98957A809 (ASTM A193 Grade B7 Alloy Steel Threaded Rod Plain Finish, 1/2"-20 Thread, 2' Length)
Local auto parts store:
(4) 1/2-20 lug nuts that use a 3/4" wrench
Local hardware store (or Fastenal, or McMaster, if you don't have a good one close)
(4) 1/2-20 x 3.5" long bolts, grade 8
(4) 1/2-20 prevailing torque nuts (nuts with a crimp on one side, so you can't put them on by hand. They take a wrench the whole way.)
(8) 1/2" grade 8 lock washers
(4) 3/16" tractor pins (the kind with the ring that flips around to hold them in place)
So, you cut the all-thread and put it into the heims at whatever length works for your setup (I usually go ~1-1.5" or so longer than stock). The heims are done.
Onto the bolts... While there's still a bolt head put the lug nuts on tight to the end of the threads, with the taper pointing toward the non-threaded part of the bolt. Then cut off the bolt head, and clean the cut up.
Next, stick the bolt in a vice on the drill press, and drill a hair bigger than a 3/16" hole ~3/8" from the freshly cut end.
Now, you just put it all together. The order goes, from the cut end:
- cut end
- tractor pin
- lock washer (this just spreads the load out. Pins seem to bend on occasion without the washer there)
- heim
- lug nut
- mounting flange on the control arm
- lock washer
- prevailing torque nut
Somewhat like this, except with female heims and only 1 lock washer where the nuts go:
by Kuchar09 » Wed Jul 25, 2012 9:47 pm
I'm looking at making these and noticed the part number is wrong.
(1) 98957A09 (ASTM A193 Grade B7 Alloy Steel Threaded Rod Plain Finish, 1/2"-20 Thread, 2' Length)
I believe that is correct since nothing showed up with your part number.
Thanks for this info by the way!!
Kuchar09
by bartonmd » Wed Jul 25, 2012 10:25 pm
by Skidder » Fri Nov 02, 2012 8:02 am
Mike,
When you get the time, could you develop a complete McMaster part number list for this project?
Skidder
by Moots1288 » Fri Nov 02, 2012 9:03 am
by bartonmd » Fri Nov 02, 2012 4:47 pm
Thanks moots! Yeah, if you look back a few posts, I posted the full p/n and how-to.
by bartonmd » Fri Nov 02, 2012 4:51 pm
Went back and looked. The parts that don't have mcmaster numbers I got elsewhere. The mcmaster bolts don't have enough thread on them in that length, so i used them from fastenal. Also got the prevailing torque nuts from there, and the pins from Rural King. Mcmaster doesn't have lugnuts, so i got those from my local auto parts store.
by mason10198 » Wed Oct 07, 2015 4:50 pm
I created a super quick webpage with hyperlinks to the part numbers and instructions based on .
The site I created is here:
| Mason | | | |
by HARDTRAILZ » Wed Feb 22, 2017 10:20 am
Return to MDB Fabrication
