by Trail X » Sun Jan 22, 2012 9:12 pm
Seeing as you have effectively provided us zero information about what failed in the first place, and zero information on your diagnosis, we can't really advise you on much right now.
Do the test we suggested (both front wheels off the ground, lifted by frame). That is the only way to determine if you are binding up your axles, which could indeed cause issues in your diff and disconnect.
