offroadTB.com • View topic - front dif rebuilt due to lift
by mk3smitty » Fri Jan 06, 2012 5:43 pm
i put a 4 inch lift on my tb 2 months ago and i was having problems with my 4wd first my cv boots were blowing left and right so i purchesed some HD axles and now they are fine. about a week ago i began hearing a clicking nose coming from my pass side and realize something was ether wrong with my 4wd disconnect or my front dif so i took it to the dealer because it is under warranty and the said my dif was blown due to my lift and they addvised me to remove it. im just wondering everyone input on this and if there is anything i can do to prevent my dif from going out agin.
mk3smitty
by bartonmd » Fri Jan 06, 2012 5:51 pm
Bullshit.
Your front diff is broken partially because of doing what you're doing in that picture...
The only way I could POSSIBLY see the lift doing anything bad to your diff, is if it's the bearings on the output... Ring gear, pinion gear, carrier, spider gears, carrier bearings, etc. etc... All of those aren't caused by the lift... More specific information is needed.
by chevycrew » Fri Jan 06, 2012 5:55 pm
4" lift? Thats quite a bit. Search on here, there are tons of threads that discuss the issues with being lifted.
by bgwolfpack » Fri Jan 06, 2012 5:57 pm
by mk3smitty » Fri Jan 06, 2012 6:04 pm
mk3smitty
by mk3smitty » Fri Jan 06, 2012 6:06 pm
mk3smitty
by chevycrew » Fri Jan 06, 2012 6:13 pm
The point with me mentioning 4" is the angle that everything in the front end is at. Is that 4" of suspension lift, or do you have a body lift for part of that? Do you have any CV binding at full droop?
by mk3smitty » Fri Jan 06, 2012 6:23 pm
mk3smitty
by v7guy » Fri Jan 06, 2012 6:25 pm
Ive had problems with boots tearing, but the CVs are fine.
If you drown your diff and dont have a hose on the vent to keep water from pouring in you're not doing your diff any favors... or the places you wheel for that matter.
Do you have pictures?
by mk3smitty » Fri Jan 06, 2012 6:28 pm
mk3smitty
by mk3smitty » Fri Jan 06, 2012 6:29 pm
and ill have pics as soon as i get the tb back
mk3smitty
by chevycrew » Fri Jan 06, 2012 6:33 pm
If you have a 4" spacer in the front (id like to see pictures of that) then you have much more than 4" of lift.
by mk3smitty » Fri Jan 06, 2012 6:37 pm
im just telling you the kit that i ordered and put on bud, all i was trying to do was get a little input the lift i put on did bring my truck up about 3 3/4'' all around
after
before
mk3smitty
by chevycrew » Fri Jan 06, 2012 6:46 pm
ok then its not a 4" block, but a 4" lift.
Info is king, it helps us, help you...
by bgwolfpack » Fri Jan 06, 2012 6:49 pm
by mk3smitty » Fri Jan 06, 2012 6:50 pm
yes i just miss understood you
mk3smitty
by mk3smitty » Fri Jan 06, 2012 6:51 pm
well if i had my truck i would get you pics but the dealer has it so thats kind of impossible right now
mk3smitty
by chevycrew » Fri Jan 06, 2012 7:00 pm
What brand is the kit?
Snap some pics when you get the truck back too.
by mk3smitty » Fri Jan 06, 2012 7:09 pm
not sure the mwr on base ordered it and installed while i was deployed and my wife picked it up it was a suprise for my return home lol so i havnt really paid it no mind my main concern has been finding a good set of shocks maybe even just goin straight axle like i did on my yota but this is my daily driver so not to sure on that one yet but as soon as i get it back i will post the dealers report and snap some pics
mk3smitty
by chevycrew » Fri Jan 06, 2012 7:23 pm
all the info you need is on this site...
shocks, sas, etc.
