offroadTB.com • View topic - Mike's Bumpers...
Mike's Bumpers...
Moderator: bartonmd
by Skidder » Sun Dec 25, 2011 11:48 pm
Been thinking about one of Mike's bumpers for my TB...unfortunately, Santa didn't bring one this year. That just means I'll have to get one myself. So, I need to figure out what options I 'need'. In PMs with Mike on the subject, he has a great 'if you can think about it, I can build it' frame of mind. But the downside of that kind of great attitude/aptitude, is I have to be smart enough to tell him what I want.
As I try to get smart enough, I have narrowed what I want, to match what I need. I know I'm not planning on a body lift, and that I want the increased protection for the front end that a full brush guard will give. What I don't know/haven't been able to find, is the dimensions of the upper section of the bumper where the brush guard tubes will mount.
Are the dimensions of the body lift and non body lift bumpers the same, except for the part that slants toward the truck (where the brush guard will mount)? How much difference is there between the lift and non lift version on this section?
Skidder
by Skidder » Sun Dec 25, 2011 11:59 pm
As a follow-up question...is the '06+ LT bumpers to the product line photo from the March 06, 2011 posting, a body lift bumper? And, will an 06 bumper fit on an 02?
Skidder
by Rob93 » Mon Dec 26, 2011 2:24 am
Take a look at the front end of an 06 LT and the standard front end... 06 grill dips down farther and thus has a different bumper cover. It'll bolt up of course but wont fit the body lines
Rob93
by bartonmd » Mon Dec 26, 2011 9:25 am
Yes, the '06 LT bumper that I've done was a 3" body lift...
The vertical front part of the 3" body lift bumper is slightly taller than the standard body lift...
What usually works out better for me, and what will work out better for you, in the end, is if you can tell me shapes and features you want, and I can work out the dimensions... I don't need you to tell me you need the top to be 3.45" from X or Y, unless you just want to... I can put a brush guard on pretty much anything, even a standard non-body lift bumper, so on your end, that should be sort of a "and I want a tube brush guard" kind of a thing...
The question is, which direction do you want to go? Like start with my standard, angled top, or start with a custom flat top/angled bottom, like James' or the 3" body lift winch bumper I just sent to powder coat? A big part of that is whether or not you want a winch to be in it, or whether you want it to be on a 2" receiver mount?
I guess the point is, if you give me parameters to work around, I can come up with something in CAD or in a sketch, and see if you like it... You don't need to actually DESIGN it, if you don't want to...
by navigator » Mon Dec 26, 2011 12:16 pm
For me if I weren't concerned about cost, I would get the bumper with the 2 inch receiver, 2 shackle mounts, the cutouts/tubes for the 3.5 inch driving lights and a brush guard. I would also go ahead and get a radiator skid plate as well.
by Skidder » Mon Dec 26, 2011 3:21 pm
Yep, that is the plan...but with both skid plates. I just have to figure out what the brush guard needs to look like.
Skidder
by navigator » Mon Dec 26, 2011 3:57 pm
this one is nice with the brush guard.
I think I like this one the best myself but I would leave off the small outside lights.
by bartonmd » Mon Dec 26, 2011 5:14 pm
by HARDTRAILZ » Mon Dec 26, 2011 6:14 pm
I just show up and things get welded. Seems to work out...
by navigator » Mon Dec 26, 2011 6:32 pm
hmm, but y'all are 13 hrs away I can't just drop by....
by HARDTRAILZ » Mon Dec 26, 2011 6:41 pm
Details details
by Skidder » Mon Dec 26, 2011 8:30 pm
Mike, Is there a photo of a non-body lift 06+ bumper?
Skidder
by dirty anton » Mon Dec 26, 2011 9:12 pm
mike the work on yours and kyle's bumpers looks great. i get asked about the bumper all the time from jeepers and other truck owners were to get one. :cheers:
dirty anton
by bartonmd » Mon Dec 26, 2011 9:49 pm
by fishsticks » Mon Dec 26, 2011 10:00 pm
Moved this to Mike's section.
Carry on. 8-)
by dirty anton » Mon Dec 26, 2011 10:46 pm
man its tempting mike :drool3: but i may have to work out my other issues at hand first. thanx tho!
dirty anton
by Skidder » Tue Dec 27, 2011 11:58 am
Mike, Mounting wise, will a bumper (no body lift) for 06+ fit on an 02?
Here's what I am thinking... if it does, that will create a hole between my 02 grille and the bumper's drop in the middle, where the newer grill drops below the lights. Depending on the dimensions of the dropped section (middle), I could mount the vertical portion of the brush guard in the drop, angling the center sections of the brush guard to match the lines between the grill and the lights (the angle being like James' WAAG mod on his bumper). Then, depending on what the hole between the bumper and my grill is, size wise, I could then mount a horizontal bar between the verticals, over the hole, which would allow lights that would be taller than a winch mounted on the 2" receiver. Then, run the brush guard out over the headlights (like James'), but maybe have the ends attach to the wings on the bumper...
Skidder
by bartonmd » Tue Dec 27, 2011 12:27 pm
by Skidder » Tue Dec 27, 2011 1:29 pm
Cool beans. My use of James' bumper was really just for the angle, not really for the design with the rubber. But, now that you mention it, can you model both?
Skidder
by bartonmd » Tue Dec 27, 2011 1:34 pm
Return to MDB Fabrication
