offroadTB.com • View topic - 4Crawlin Build Thread
by bartonmd » Fri Apr 29, 2011 9:06 am
by HARDTRAILZ » Fri Apr 29, 2011 9:09 am
by navigator » Fri Apr 29, 2011 9:44 am
I saw the note about the bumpstops he just won't have much travel before it bumps.
With a straight axle if you limit the up travel on one side doesn't it directly affect down travel on the other side?
I guess with 42's you don't need much travel then again you might just need more lift :-)
by bartonmd » Fri Apr 29, 2011 9:54 am
by Trail X » Fri Apr 29, 2011 9:55 am
by bartonmd » Fri Apr 29, 2011 10:00 am
If travel is only going ~3" up from resting height, like it looks, the drag link should be OK sitting under the front crossmember of the subframe, there... The steering box may have to be a bit low, though...
by dirty anton » Fri Apr 29, 2011 11:09 am
in thinking this sas in my head and discussing with someone having done swaps before ,those with a 3 in body lift could raise the motor up 3 inches? this was briefly
brought up a while ago by fish.it would gain a few more inches possibly needed.
dirty anton
by chevycrew » Fri Apr 29, 2011 11:47 am
Ok, Ill try to address everything.
Springs are stock 73-87 chevy 52" rear springs.
Full weight is on the front springs.
My last crawler had the bumpstops at 2" above the springs, no issues at all with travel. You really dont want to flex the spring into a negative arch anyway.
When one side hits the bumpstop, the other side can droop further, with the axle pivoting around the bumpstop it is contacting. Most coilover, or leaf sprung crawlers are set with very little up-travel, and lots of droop. Works well for stability and center of gravity.
Yes, draglink will be very tight, Im also running high steer, with hydro assist. Steering gearbox make, and placement is still undecided.
Body lift will allow engine to be raised, but you need to raise the trans, and radiator to match. If your going to that trouble, why not put more suspension under it?
:lurk:
Here is a major problem for those also considering this swap. A Dana 44 will require MUCH more lift. While my Dana 60 has the diff offset to the drivers side a good amount, a Dana 44 diff will sit underneath the oil pan, my closest point is the drain plug to the top of the axle tube. The 60 diff clears to the drivers side of the oil pan.
by fishsticks » Fri Apr 29, 2011 11:50 am
by chevycrew » Fri Apr 29, 2011 11:59 am
Messing around with mockup again.... Looks like it still needs to go up about 5" to bolt on the tire.
Its also going to be a wide b*tch!
Picture quality sucks, just using my phone. Im to lazy to get out the good camera
by dirty anton » Fri Apr 29, 2011 12:02 pm
good to know about the oil pan no being as critical an issue with the proper axle.....
thoughts on a ford 9 inch?
holy crap that is wide!
dirty anton
by chevycrew » Fri Apr 29, 2011 12:05 pm
by chevycrew » Fri Apr 29, 2011 12:07 pm
by dirty anton » Fri Apr 29, 2011 12:18 pm
thanx for all the insight.... that's gonna be a monster when done!
dirty anton
by chevycrew » Sun May 01, 2011 12:25 am
Got the weight of the truck sitting on the front 42s, rear is still on jackstands.
Overall height roughly, 85"
Ground to top of front fender opening, 50"
Ground to bottom of frame under drivers door, 24"
Tire width outside the fender, 10"
Im going to be setting the bumpstops 2" off of the springs, using a fairly hard poly bumpstop.
I have a couple reasons to bumpstop it. Springs are within about an inch of being flat. When turned to full lock, tire is only 4" below the tube part of the core support behind the headlight. Im sure it will rub on that. Still need to trim the fender behind the tire too.
Steering, yay... I took out the shaft between the column and the rack, chopped it up, and ended up with a much shorter shaft. Now it should be easier to get good angles on the shaft to the new steering gearbox. Gearbox choice is up in the air, but its looking like a toyota IFS box will do the trick. Drag link will actually sneak between the oil pan, and the front crossmember. I have arms to do full high steer, but the tie-rod is tight to the bottom of the leafs while mounted on top of the stock TRE holes in the knuckle, so, it is going to stay there. That also allows easier mounting of the hydro ram.
I think thats it for the days work.
by chevycrew » Wed May 04, 2011 11:29 am
Made more progress..
Rear spring pocket, this was the old lower control arm pocket.
Rear springs hung.
And clearance at ride height with tires at full lock.
by chevycrew » Wed May 04, 2011 11:36 am
And, this should get some looks!
Truck is coming together very quickly:
by Gordinho80 » Wed May 04, 2011 11:40 am
You're gonna have to air down to get it out of the garage! I love this build! :cheers:
Mario -
by janesy86 » Wed May 04, 2011 11:51 am
Awesome progress! Coming together very nicely so far!
by HARDTRAILZ » Wed May 04, 2011 12:00 pm
Well done. Should definitely turn some heads and crawl some rocks.
