offroadTB.com • View topic - 4Crawlin Build Thread
by dirty anton » Tue Apr 19, 2011 11:49 pm
movin along well! very nice.....very nice
dirty anton
by chevycrew » Wed Apr 20, 2011 12:03 am
Thanks! Im trying, but getting garage time is hard these days.
by bdp1978 » Wed Apr 20, 2011 10:13 am
Nice work, moving right along!!
Also nice Hornets Nest you stirred up on the OS! Cracking me up.
bdp1978
by chevycrew » Thu Apr 21, 2011 11:12 am
I pulled out my radiator and thermostat, found the t-stat problem.
Sucks to have to do it on a rig I just bought, but when done, the new radiator, t-stat, and hoses will give me some peace of mind.
by chevycrew » Fri Apr 22, 2011 1:06 am
Thermostat is in, but waiting on my radiator...
So to keep going: I pulled both driveshafts, its all up hill from here.
by Trail X » Fri Apr 22, 2011 9:02 am
Why did the radiator need replacing? Was it leaky?
by chevycrew » Fri Apr 22, 2011 11:46 am
Yeah it was leaking coolant from around where the transmission lines tie in. I didnt want to mess with attempting to reseal it.
by chevycrew » Sat Apr 23, 2011 1:21 pm
Ok, swapping my transfer cases.
3 speed sensors on the original t-case. Which one is for the speedometer? I need to change the plug to have it hook to the new t-case?
Worst case I could trial and error, but thats down the road a ways.
by Trail X » Sat Apr 23, 2011 1:40 pm
by chevycrew » Sat Apr 23, 2011 4:09 pm
Thanks,
So in the process of swapping cases, I keep finding crap in the way.
Aluminum exhaust hanger- Removed
Muffler- Removed
Now for the third time of test fitting, I hope it goes in!
by HARDTRAILZ » Sat Apr 23, 2011 5:19 pm
Good luck. Try and toss of pics if you get a chance. I like the spring hanger mount in the front. It got me to go out and poke around my Suburban. Thinking swap from TC to tires and go big. Can always work out a link suspension later after working out the major bugs. Thanks for working on this and sharing the ideas and progress.
by chevycrew » Sat Apr 23, 2011 7:50 pm
Duals are in!
A little tighter clearance between the tank and the transfer case than I would like, but it will have to work for now. Im planning on cutting off the tank mounts and sliding them back an inch or so.
I still need to work out shifters, along with vss wiring.
by dirty anton » Sat Apr 23, 2011 9:46 pm
wow tight it is! this is really great
dirty anton
by chevycrew » Sat Apr 23, 2011 9:55 pm
Thanks.
For those interested, its a standard 27 spline output on the 4l60e. Uses the 5 bolt round adapter, same as the s10 platform.
by chevycrew » Mon Apr 25, 2011 12:34 am
Got a little crazy with it today...
by JamesDub » Mon Apr 25, 2011 12:57 am
Now thats an impressive pile of parts you have . I can't wait to see your build as it all comes together :thumright:
The DubMobile is getting a makeover !
JamesDub
by Trail X » Mon Apr 25, 2011 8:52 am
Curious, are you doing spring under, or spring over suspension?
by HARDTRAILZ » Mon Apr 25, 2011 8:57 am
With those spring he has to go spring over. It is pretty rare to see a spring under setup these days and would take some serious custom spring packs for his goals.
by Trail X » Mon Apr 25, 2011 9:00 am
Thanks, I know a little about leaf springs, but admittedly not a whole lot. I know spring under tends to give extra axle wrap, but it gets the springs a little more out of the way.
by chevycrew » Mon Apr 25, 2011 10:15 am
Yep, spring over. -m using stock 52" Chevy rear leaf springs for the front and rear. Easy to find to replace when broken.
Steering isn't going to be as bad as first expected. The u-joint in the shaft allows enough angle to change directions to forward and run to a box. Pillow block will be needed, but it should work out well.
If it all comes together, it should be sitting on tires next weekend. Then the long road to working out all the details.
