offroadTB.com • View topic - If you need coil spring compressors...Don't buy from here!
by steveroche » Tue Apr 19, 2011 10:19 pm
So i was planning on what i needed for doing my lift kit install and one of the things that i did not have in my workshop was coil spring compressors, a necessary tool to complete the suspension lift install. So i went on Ebay to find a set of manual compressors which i could buy for under 75 bucks so i wouldn't have to spend a bunch of money on something hydraulic. I ended up coming across a set that looked to be good quality and definitely strong enough to take care of the job. I purchased from mydealsdirect on ebay and was very pleased with the quick ship time. I kept it all boxed up and sealed until the day of the lift about a month later. When compressing the springs using both compressors at once under correct usage procedures, BOTH compressors broke and shot out across the garage and one of them nailed me in the leg. I emailed them immediately after i finished everything up(luckily have a friend with a wall mounted compressor as a backup) and they refused to refund payment because it was past the 30 day refund guarantee. I just want to get this out there so if anyone is looking through this lift/suspension section about putting in the lift kit they can see this so they don't buy compressors from these guys.
steveroche
by Blackout » Tue Apr 19, 2011 10:22 pm
You can rent them at Auto Zone for a refundable $50.
Sears has them for around 45 as well.
Blackout
by steveroche » Tue Apr 19, 2011 10:27 pm
i ended up using a wall mounted one and got them assembled and installed. just want to let people know not to buy the cheap crap these guys sold me.
I probably should have called autozone for a rental haha
steveroche
by Flying Monkey » Tue Apr 19, 2011 10:55 pm
Good to know because ill be hunting a spring compressor here soon and wont be looking to spend alot as I wont use it very often at all to justify it.
Flying Monkey
by gotspeed1 » Tue Apr 19, 2011 11:00 pm
Having played with these, and had one come apart, this is something you definitely don't won't to go CHEAP on. :shoot:
gotspeed1
by DJones » Tue Apr 19, 2011 11:29 pm
Good thing that nobody lost any limbs of fingers with all that stored energy. Maybe the were cheap to be "ricer rated".
David
DJones
by steveroche » Tue Apr 19, 2011 11:40 pm
here are some pics of the broken pieces
Here is the single hook side...also clearly sheared off
you can clearly see the bolt bent out of shape
Here is the double hook, you can clearly see where it sheared off
steveroche
by gotspeed1 » Tue Apr 19, 2011 11:43 pm
The ones I've gotten from Auto Zone are of (what looks like) considerably higher quality. I'd try those. They haven't failed me and as someone else already stated, they're like $50 to rent. :coffee:
gotspeed1
by fishsticks » Wed Apr 20, 2011 12:45 am
Those have got to be the worst designed compressors I've ever seen.
by Trail X » Wed Apr 20, 2011 8:30 am
by steveroche » Wed Apr 20, 2011 9:37 am
steveroche
by Regulator1175 » Wed Apr 20, 2011 12:46 pm
Wow! :awesome:
That is one more reason for me to be happy to take the entire strut assembly to Midas and let them take care of the work for ten bucks a side.
by bgwolfpack » Wed Apr 20, 2011 2:30 pm
by b taylor » Wed Apr 20, 2011 9:50 pm
I did mine with some cheap ones from Harbor Freight, I used them once and don't think I'll use them again, it definatly took a few years off my life!!
b taylor
by Flying Monkey » Wed Apr 20, 2011 10:18 pm
After reading this thread Ive decided to definitely not do the springs myself for the front. I have a buddy who owns a garage and ill ask him about if he has a compressor or just take them somewhere that does if he dont to do it. My luck isnt so hot so no point in taking chances lol.
Flying Monkey
by gotspeed1 » Wed Apr 20, 2011 10:30 pm
gotspeed1
by steveroche » Fri Apr 22, 2011 12:39 am
steveroche
by Harry Moto » Thu May 05, 2011 4:11 am
2008 TB, 1.75" Smaxx front, 1.25" wheel adapters, 255/75-17 Silent Armor, compass mirror, 7" indash DVD/GPS, power passenger seat, & Mikes steel skid plate.
Harry Moto
