Bronco Style tire carrier
by Me007gold » Fri Apr 01, 2011 4:55 pm
Has any one tried this yet? Seems like it could work fairly well on our trucks if some one has a small amount of skill. Is the body strong enough to support this?
Me007gold
by Hatchet669 » Fri Apr 01, 2011 5:19 pm
i thought of the same thing a while ago (cept the blazer style) i believe the body wont handle it with out reinforcment... but its been a long time since i last looked into it...
Hatchet669
by janesy86 » Fri Apr 01, 2011 5:23 pm
Yea, its been talked about before. Not much behind the sheet metal. Would take a good deal of work to beef up. I really like karo's design for the rear carrier, very sleek...
by Diacom » Fri Apr 01, 2011 8:40 pm
Well, if you don't mind cutting the rear bumper cover for the lower mount to get into a stronger structure for mounting, then all you'll have to do it figure the upper mount reinforcement.
Basically you'd have to have it fold down rather than to the side is what i'm getting at.
by bgwolfpack » Fri Apr 01, 2011 10:29 pm
Not only is the metal soft but you'll need a stick to hold the hatch up. Otherwise I'd suggest attaching to the hinge portion of the hatch at the top where the metal is far more robust. Keep thinking though! :coffee:
by Trail X » Sun Apr 03, 2011 10:36 pm
Ran, the tire mount would be to the sheet metal around the tail light, not the tail gate itself.
I think it could work, you'd just have to really reinforce the inside of the attachment areas. Because you'd mount it on the corner of the sheet metal, it should have enough rigidity to handle the weight of the tire, especially with the attachment points spread so far apart.
the biggest challenge would be building up the area under the tail light, as that's currently just plastic.
by navigator » Mon Apr 11, 2011 3:16 pm
there isn't a lot of detail but I don't think the jeep XJ has any stronger sheet metal than we do and this guy was able to do it.
http://www.jeepforum.com/forum/f11/bronco-tire-carrier-its-good-thing-855315/
by bartonmd » Mon Apr 11, 2011 3:51 pm
With the XJ being a uni-body, I'd say that their sheet metal is probably a bit stronger than ours... Have you pushed on our sheet metal? It's really pretty thin...
by Trail X » Mon Apr 11, 2011 4:30 pm
bartonmd wrote:With the XJ being a uni-body, I'd say that their sheet metal is probably a bit stronger than ours...
I'd doubt that area of the body is built to take any more chassis stresses than ours.
by bartonmd » Mon Apr 11, 2011 4:37 pm
The material feels a quite a bit thicker back there on the XJ than it does on the TB...
by OregTrailBlazin » Mon Apr 11, 2011 5:01 pm
bartonmd wrote:
JamesDowning wrote:I'd doubt that area of the body is built to take any more chassis stresses than ours.
I agree.. Looking at my dads jeep, I think the internal support on the back of the XJ is all the way to that outer layer of the body, but on ours its further inside the body structure... If that makes sense, it's monday and my brain is fried :gimp:
Johnny Kurz
General Manager
541-474-2879
Wheeler's Off-Road Inc.
Our Vendor Section
OregTrailBlazin
by navigator » Mon Apr 11, 2011 7:22 pm
If I had seen this about 2 weeks ago there was a junker sitting in my yard I could have cut a panel out to take a look.
I have another one in the yard but I doubt my son would appreciate if I cut a hunt out of it.
looking at my TB though there might not be enough real estate there anyway.
Return to Fab Work
