Body lift bolt length.
by chevycrew » Fri Mar 18, 2011 9:07 pm
For those that have done a body lift. Is there enough of the factory bolt length to do a 1" body lift and still have full thread engagement?
Im planning on running a small 1"-2" body lift to help with space around the trans and t-case, sneaking 1" in would be nice.
by fishsticks » Fri Mar 18, 2011 9:30 pm
chevycrew wrote:For those that have done a body lift. Is there enough of the factory bolt length to do a 1" body lift and still have full thread engagement?
IIRC there wouldn't be enough thread left over to make me comfortable running a BL on the stock bolts.
by chevycrew » Fri Mar 18, 2011 9:34 pm
Yeah I didnt think so, but some of the trucks I have played with have over an inch of extra.
by chevycrew » Tue Mar 22, 2011 11:42 pm
So for those wanting to play around with their own body lift. (without taking out all the stock bolts.)
Does anyone have some stockers to measure? or know the measurements?
Im looking for size, length, thread pitch, and quantity of each.
Thanks!
by The Roadie » Tue Mar 22, 2011 11:49 pm
www.compnine.com ( a site you should bookmark) gives this description:
BOLT,HFH,M12X1.75X115.5,24 THD,26.6 OD,10.9,6173M,MACH
by chevycrew » Wed Mar 23, 2011 12:20 am
Thanks! That made it easy knowing they are all the same.
by fishsticks » Wed Mar 23, 2011 12:39 am
There are two in the very front that aren't shown there. IIRC they are 2" longer than the others... or was it shorter?
by chevycrew » Wed Mar 23, 2011 12:46 am
From the zone pic, they show 10 the same length, then 2 about 2" longer, then 2 more 2" even longer.
I should have noticed the front 2 cut off.
Edit:
Ill read through zone install stuff, that should tell me what bolt goes where.
Edit #2:
Looks like for a 2" lift, front locations take 200mm bolts, while the rest take 160mm
by chevycrew » Wed Mar 23, 2011 2:13 am
Im not having much luck finding the gm part number for the front body mounting bolts, the ones going through the radiator support.
by fishsticks » Wed Mar 23, 2011 3:10 am
PM MarkMC... He used to make the body lift that quite a few of us run. I'm pretty sure he'll know what size they are.
by markmc » Wed Mar 23, 2011 5:47 am
Not sure what the stock bolt lenght is, but here is the length i used for the 3" body lift.
The very front 2 body mount bolts are m12x230
The rear 10 body mount bolts are m12x190
There are also 2 front bumper relocation bolts to raise the bumper.. those are 1/2"-13x 10.5"
hope this helps
Best place to find long metric bolts is your local John Deere or any tractor dealer.
markmc
Rank: Mall Rated
